Usefull SA Plugins
Usefull SA Plugins
Post by RvdH » 2019-03-01 14:29
Useful SpamAssassin Plugins
The purpose of this topic is to share information on (custom) plugins that can be used with SpamAssassin used by forum members here
DecodeShortURLs
This plugin looks for URLs shortened by a list of URL shortening services and upon finding a matching URL will connect using to the shortening service and do an HTTP HEAD lookup and retrieve the location header which points to the actual shortened URL, it then adds this URL to the list of URIs extracted by SpamAssassin which can then be accessed by other plug-ins, such as URIDNSBL.
https://github.com/smfreegard/DecodeShortURLs
HashBL (This is version 0.3 a improved version over the 0.1 version included in SA 3.4.2)
This plugin is used to lookup e-mail addresses on the msbl.org blacklists.
https://github.com/smfreegard/HashBL
Well, this is my contribution....what do other's here use? Either default disabled plugins or custom plugins
Re: Usefull SA Plugins
Post by SorenR » 2019-03-01 17:27
Botnet looks for possible botnet sources of email by checking various DNS values that indicate things such as other ISP's clients or workstations, or misconfigured DNS settings that are more likely to happen with client or workstation addresses than servers.
https://github.com/eilandert/Botnet.pm
NOTE: HashBL is already part of SA 3.4.2 standard plugins. All you need to do is create the config HashBL.cf
loadplugin Mail::SpamAssassin::Plugin::HashBL
ifplugin Mail::SpamAssassin::Plugin::HashBL
    header   HASHBL_EMAIL	eval:check_hashbl_emails('ebl.msbl.org')
    describe HASHBL_EMAIL	Message contains email address found on the EBL
    score    HASHBL_EMAIL	0.1
    meta     HASHBL_EMAIL_BLACK (0)
    describe HASHBL_EMAIL_BLACK Message contains email address found on the EBL Black list
    score    HASHBL_EMAIL_BLACK 3.0
    meta     HASHBL_EMAIL_GREY  (0)
    describe HASHBL_EMAIL_GREY  Message contains email address found on the EBL Grey list
    score    HASHBL_EMAIL_GREY  1.0
endif
Just about a week ago I copied the entire .\Mail directory with plugins and the works from 3.4.2 SOURCE to my 3.4.0 installation overwriting the old files. So far everything is still working :mrgreen:
Post by RvdH » 2019-03-01 19:26
2019-03-01 17:27
Nah, it isn't...SA 3.4.2 uses 0.001 and the github link for HASHBL above is 0.003 that includes the splitting into BLACK/GREY rules
