warn: bayes: cannot open bayes databases
thomas10
Post by thomas10 » 2018-05-31 12:38
Hi All,
Recently, I found that sometimes in the spamd, it mentioned about Bayes: cannot open bayes database. Below is the sample:
Thu May 31 17:40:49 2018 [-2928] info: spamd: connection from GCF [127.0.0.1]:58866 to
port 783, fd 7
Thu May 31 17:40:49 2018 [-2928] info: spamd: processing message
<1631725236.2618.1527759593372.JavaMail.pie_ek@hqibm303.hq.emirates.com> for (unknown):0
Thu May 31 17:41:00 2018 [-2928] warn: bayes: cannot open bayes databases
C:\Windows\system32\config\systemprofile\.spamassassin/bayes_* R/W: lock failed: File
exists
Thu May 31 17:41:00 2018 [-2928] info: spamd: clean message (-2.6/5.0) for (unknown):0 in
10.8 seconds, 5979 bytes.
Thu May 31 17:41:00 2018 [-2928] info: spamd: result: . -2 -
BAYES_00,HTML_MESSAGE,JAM_DO_STH_HERE,KHOP_RCVD_UNTRUST,MIME_HTML_ONLY,RCVD_IN_DNSWL_MED,RCVD_IN_HOSTKARMA_W,URIBL_BLOCKED
scantime=10.8,size=5979,user=(unknown),uid=0,required_score=5.0,rhost=GCF,raddr=127.0.0.1,rport=58866,mid=<1631725236.2618.1527759593372.JavaMail.pie_ek@hqibm303.hq.emirates.com>,bayes=0.000000,autolearn=unavailable
 autolearn_force=no
Thu May 31 17:41:00 2018 [-2928] info: spamd: child got SIGINT, exiting
Thu May 31 17:41:00 2018 [4012] info: prefork: adjust: 3 idle children more than 2 maximum
 idle children. Decreasing spamd children: -2928 killed.
Thu May 31 17:41:03 2018 [4012] info: spamd: handled cleanup of child pid [-2928]: exit 0
But it doesn't happen everyday. Can anyone explain on what it is and the impact when it appeared? Thanks so much. :D
Regards,
Thomas
Re: warn: bayes: cannot open bayes databases
Post by jimimaseye » 2018-05-31 13:54
I dont know myself. You might be better off asking Jam support. They are usually quite useful.
