whitelist subject
whitelist subject
Post by palinka » 2017-11-29 23:11
I have a php mail form that anyone can fill out. Its working, but some emails including real accounts trigger spam. The form has a fixed recipient and subject line. I want to whitelist the subject line so that any sender will not get a spam tag.
I looked around and found this, but it hasn't worked for me: https://wiki.apache.org/spamassassin/Wh ... jectPlugin
I think I followed the instructions properly. It looks fairly simple. Maybe I overlooked something. I restarted apache (on xampp) and hmailserver after making changes for good measure.
I also tried to add a couple of rules, including adding header X-hMailServer-Whitelist = YES when the subject contains the fixed subject referenced above, but rules get processed after spamassassin, so that didn't help.
Any help getting this sorted would be greatly appreciated.
Re: whitelist subject
Post by mattg » 2017-11-29 23:28
Did you install that plugin as well as make changes to your .cf (configuration file)?
Post by palinka » 2017-11-30 00:10
mattg wrote:Did you install that plugin as well as make changes to your .cf (configuration file)?
I made the changes to local.cf and WhiteListSubject.pm already exists, and I modified it like shown. Is WhiteListSubject.pm the plugin or is there another file? Thanks for responding.
Post by palinka » 2017-11-30 01:06
I rebooted my server and that seems to have solved the issue. I'm not sure why that would be the case since I stopped and started both apache and hmail services a few times to no effect. I'm not even sure if changes to these things require service restart.
Post by mattg » 2017-11-30 01:24
SpamAssassin would NOT be affected by either a hmailserver or Apache restart. You would need to restart the server as you did or restart the SpamAssassin service to have effect.
Post by jimimaseye » 2017-11-30 01:26
mattg wrote: restart the SpamAssassin service to have effect.
Exactly that. Always required after a change b to .c.f. files and updates.
Post by palinka » 2017-11-30 16:36
OK great, I didn't think about that. Thank you. I'll keep that in mind next time I make changes.
