Block Spammed Email
Jessy14
Block Spammed Email
Post by Jessy14 » 2017-10-03 21:46
Hi Experts, We received a bunch of emails every day using our email address. Below is one of them viewed from the email property. Please advise! Thank you!
Return-Path: sales@xxx.com
Received: from [203.155.38.234] (Unknown [203.155.38.234])
by xxx.com with ESMTP
; Tue, 3 Oct 2017 09:24:44 -0500
MIME-Version: 1.0
Date: Tue, 03 Oct 2017 21:24:44 +0700
Message-ID: <dCAb2d1464489A4F49F676d93628D0c5b0b702d70959e301401@mail.gmail.com>
Subject: INVOICE
To: data@xxx.com
Content-Type: multipart/mixed; boundary=18e1101567890fe77c7c9cf1d958
Envelope-To: <data@xxx.com>
Re: Block Spammed Email
Post by jimimaseye » 2017-10-03 22:32
Spoofing is a common spam problem. Check your system is well protected - run this and post the results: viewtopic.php?f=20&t=30914
Jessy14
Post by Jessy14 » 2017-10-03 23:34
Below is the running report. Please advise! Thank you!
[code]2017-10-03 Hmailserver: 5.5.2-B2129
DOMAINS
"Domain1.com" - axxxxxxxxx.net Enabled: True
Enabled: False Max size: 0 Enabled: False
Max message size: 0 Plus addressing: False
Max size of accounts: 0
Greylisting: False
"Domain2.com" - kxxxxxx.com Enabled: True
|- "Alias1.com" - kxxxxxxx.com
|- "Alias2.com" - kxxxxxx.com
|- "Alias3.com" - kxxxx.com
Greylisting: False
"Domain3.com" - lxxxxxxx.com Enabled: True
Greylisting: False
IP RANGES
IP: 203.155.38.234 - 203.155.38.234 Priority: 20 Name: Argentina Ban
Allow connections Other
SMTP: False Antispam : False
POP3: False Antivirus: False
IMAP: False SSL/TLS: False
Local To Local - False
Local To External - False
External To Local - False
External To External - False
IP: 110.175.54.4 - 110.175.54.4 Priority: 20 Name: Australian Ban
IP: 114.217.78.63 - 114.217.78.63 Priority: 20 Name: Auto-ban: 15
IP: 117.247.232.48 - 117.247.232.48 Priority: 20 Name: Indian Ban
IP: 14.141.80.58 - 14.141.80.58 Priority: 20 Name: Indian Ban 2
IP: 103.18.122.231 - 103.18.122.231 Priority: 20 Name: Indian Ban 3
IP: 110.227.121.216 - 110.227.121.216 Priority: 20 Name: Indian Ban 5
IP: 182.72.195.155 - 182.72.195.155 Priority: 20 Name: Indian Ban 6
IP: 14.177.37.50 - 14.177.37.50 Priority: 20 Name: Inidan Ban 4
IP: 80.234.143.226 - 80.234.143.226 Priority: 20 Name: London-ban
IP: 128.199.62.244 - 128.199.62.244 Priority: 20 Name: Netherland Ban
IP: 51.39.117.1 - 51.39.117.1 Priority: 20 Name: SA Ban
IP: 123.231.125.30 - 123.231.125.30 Priority: 20 Name: Sri Lanka Ban
IP: 203.155.38.234 - 203.155.38.234 Priority: 20 Name: Thailand Ban
IP: 166.38.70.182 - 166.38.70.182 Priority: 20 Name: US Ban
IP: 173.0.51.8 - 173.0.51.8 Priority: 20 Name: US Ban-2
IP: 174.47.172.122 - 174.47.172.122 Priority: 20 Name: US Ban 3
IP: 155.195.72.182 - 155.195.72.182 Priority: 20 Name: US Bank 4
IP: 58.187.68.191 - 58.187.68.191 Priority: 20 Name: Vietmna Spam 1
IP: 171.232.39.60 - 171.232.39.60 Priority: 20 Name: Vietnam spam
SMTP: True Antispam : True
POP3: True Antivirus: True
IMAP: True SSL/TLS: False
External To Local - True External To Local - True
AUTOBANNED Local Addresses:
No entries
AUTOBAN
Autoban Enabled: True Max invalid logon attempts: 5
Minutes Before Reset: 30 (0.50 hours, 0.02 days)
Minutes to Autoban: 60 (1.00 hours, 0.04 days)
There is a total of 1 auto-ban IP ranges.
INCOMING RELAYS
No entries
PROTOCOLS
SMTP
No. Connections: 50 No Retries: 4 Mins: 30 Plain Text: False Bind:
Host: Domain2.com Empty sender: True Batch recipients: 100
Max Msg Size: 11000 Relay:- Incorrect endings: True Use STARTTLS: True
Req Auth: False Loop limit: 5
Recipient hosts: 15
Con. Sec.: None
POP3
No. Connections: 50
IMAP
No. Connections: 50 Public folder name: #Public IMAP sort: True
IMAP Quota: True
IMAP Idle: True
IMAP ACL: True
Delim: "."
ANTISPAM
Spam Mark: 5 Use SPF: True - 3 Use Spamassassin: True
Add X-HmailServer-Spam: True Check HELO host: True - 3 Hostname: localhost
Add X-HmailServer-Reason: True Check MX records: True - 3 Port: 783
Add X-HmailServer-Subject: True Verify DKIM: False Use SA score: False - 5
Subject Text: "[SPAM-HMS]"
Spam delete threshold: 5 Maximum message size: 1024
GREYLISTING:
Greylisting: True Defer mins: 5 Days Unused: 2 Days Used: 32
Bypass SPF: False Bypass A/MX: False
Greylist WHITELIST ENTRIES:
IP Address: 69.41.173.84
Greylist DOMAINS enabled:
No entries
DNSBL ENTRIES:
zen.spamhaus.org Score: 7 Result: 127.0.0.*
bl.spamcop.net Score: 6 Result: 127.0.0.*
psbl.surriel.com Score: 6 Result: 127.0.0.*
virbl.dnsbl.bit.nl Score: 6 Result: 127.0.0.*
b.barracudacentral.org Score: 6 Result: 127.0.0.*
SURBL ENTRIES:
multi.surbl.org Score: 6
0spamurl.fusionzero.com Score: 6
ru.countries.nerd.dk Score: 6
WHITELISTING
ANTIVIRUS
GENERAL:
When found - Delete email. Notify Sender: False, Notify Receiver: False
Max Message Size: 1024
CLAM AV: True Hostname: localhost Port: 3310
CLAMWIN: False
CUSTOMAV: False
Block Attachments: True
*.bat Batch processing file
*.cmd Command file for Windows NT
*.com Command
*.cpl Windows Control Panel extension
*.csh CSH script
*.exe
*.inf Setup file
*.js
*.lnk Windows link file
*.msi Windows Installer file
*.msp Windows Installer patch
*.pid
*.pif
*.reg Registration key
*.rtf
*.scf Windows Explorer command
*.scr Windows Screen saver
“.PDF.EXE
SSL/TLS
SslCipherList :
TCPIP PORTS Connection Sec
0.0.0.0 / 25 / SMTP - None
0.0.0.0 / 110 / POP3 - None
0.0.0.0 / 143 / IMAP - None
LOGGING Logging Enabled: True
Paths:-
Current: C:\Program Files (x86)\hMailServer\Logs\hmailserver_2017-10-03.log
Error: C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2017-10-03.log - !! ERRORS PRESENT !!
APPLICATION - True
SMTP - True
POP3 - True
IMAP - .
TCPIP - .
DEBUG - True
AWSTATS - .
SYSTEM TESTS
Database type: PostgreSQL
Backup directory C:\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\Storage\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\Backups\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\hMailServer is writable.
HMAILSERVER.INI
Database folder:
Type= PostgreSQL
Username= postgres
Port= 5432
Server= localhost
Internal= 0
Error 438. Out-dated version. Some fields or objects missing.
[/code]
Generated by HMSSettingsDiagnostics v1.74, Hmailserver Forum.
Post by mattg » 2017-10-03 23:49
These scripts will help >> viewtopic.php?p=68117#p68117
Post by jimimaseye » 2017-10-04 00:00
From your results I see the following:
1, You have LOCAL TO LOCAL DELIVERIES allowed without authentication required for the INTERNET range. This allows spammers to send you spam through your system and will explain some of the spam you receive. You must ENABLE AUTHENTICATION for 'local to local deliveries'.
2, You are using the 'internet ranges' to act as the autoban feature when you already have autoban enabled. However you may be finding that your autoban is not effective due to the high settings you have against it. Advice:
a, Create AUTOBAN entries for all of those 'ban' IP RANGES you have and then remove them from your IP RANGEs. You only really need the INTERNET and MY COMPUTER ip ranges.
b, Then, change your AUTOBAN settings and lower the " Max invalid logon attempts:" from 5 to 1 (or 2 maximum)
By using the autoban feature (instead of the way you do with IP Ranges) you will stop the rogue spammers connecting to your machine in the first place (rather than give then a connection and rejection). Also you dont have the hassle of keep entering them yourself (given that most spam connections have a short lifespan).
With the above changes you will be tighhtening up your system and minimising the risk of receiving those spam messages.
Jessy14
Post by Jessy14 » 2017-10-04 00:34
Thank you experts! Do you mean that all of the bans created under the IP range needs to be removed? Thank you!
Post by jimimaseye » 2017-10-04 00:37
Yes.
Also you are running an old version and should update to the latest version that features many improvements and security updates.
Jessy14
Post by Jessy14 » 2017-10-04 00:38
Verion 5.5.2
Post by jimimaseye » 2017-10-04 00:44
https://www.hmailserver.com/download
Remember: we are experts. :wink:
Jessy14
Post by Jessy14 » 2017-10-04 00:47
You suggest: Create AUTOBAN entries for all of those 'ban' IP RANGES you have.
My question: Where to create the auto ban entries?
Thank you!
Post by jimimaseye » 2017-10-04 08:55
Jessy14 wrote:You suggest: Create AUTOBAN entries for all of those 'ban' IP RANGES you have.
Thank you!
Sorry, let me clarify: by this I was suggesting that those IP RANGES that you have do not have an EXPIRY set against them as you created them manually and made them permanent. (Maybe because you thought that the ip address was constant and long term). I was suggesting that you expire them (delete them) or at least set an expiry date on them as they are unlikely to be effective any more. It will not make much difference to your system except clean it up. The above suggested changes to your autoban settings and scripts offered be Mattg will give you a greater protection and autonomy.
Jessy14
Post by Jessy14 » 2017-10-04 17:03
Thank you experts!
I am going to add the following scripts. Do I need to add my user name to this line? If oClient.Username <> "my user name" Then
Do I need to add the password and where? Appreciate!
dim authemail, authemail_value, fromemail, fromemail_value
authemail = Split ( (oClient.Username) , "@" )
authemail_value = authemail(1)
fromemail = Split ( (oMessage.FromAddress) , "@" )
fromemail_value = fromemail(1)
If LCase(authemail_value) <> LCase(fromemail_value) Then
Result.Value = 2
Result.Message = "You are only allowed to send from your domain"
Post by jimimaseye » 2017-10-04 17:25
Just add the script as displayed. No changes or password required.
Jessy14
Post by Jessy14 » 2017-10-04 19:33
Thank you!
Post by jimimaseye » 2017-10-04 19:47
Remember that script will only work if you make the amendments I explained above regarding enabling authentication.
Jessy14
Post by Jessy14 » 2017-10-04 21:42
The scripts have been added. It looks like the junk emails were blocked.
But there are too many emails queued in the server which are not delivered. Now we cannot receive the emails any more. Please advise! Thank you!
Post by mattg » 2017-10-04 23:13
clear the queue (right click on the queue and 'clear')
ALL mail will be removed (including any genuine mail - this will all be lost)
You will then need to remove yourself from BlackLists
Good luck
Jessy14
Post by Jessy14 » 2017-10-05 16:34
After removing the scripts, it is fine now. BTW I didn't have anything on the blacklist. How to remove myself from the blacklist? Thank you!
Post by mattg » 2017-10-05 23:44
Check this list http://mxtoolbox.com/blacklists.aspx
Each Blacklist has their own removal process
cf.harper
Post by cf.harper » 2017-11-07 17:18
I need some spam for research purposes. So hopefully spammers will scan this email address cf.harper@yandex.com
