Hardening hMailServer - The ongoing saga!
Post by SorenR » 2019-01-28 17:09
INDEX
#1 How to become really annoying to spammers without using GreyListing. --> viewtopic.php?p=209542#p209542
#2 How to only allow client access from specific GEO locations. --> viewtopic.php?p=209543#p209543
#3 How to stop the annoying half-connections from BOT's and misconfigured spammers. --> viewtopic.php?p=209545#p209545
#4 How does a fully functioning system look like? PART 1! --> viewtopic.php?p=209546#p209546
#5 How does a fully functioning system look like? PART 2! --> viewtopic.php?p=209546#p209547
NOTE:
Some of the solutions refer to external functions that require implementing:
Sub OnHELO(oClient) is NOT available in the original compilation.
If you wish to make use of this added trigger please see viewtopic.php?p=206039#p206039
ActiveX object DNSLibrary can be obtained from https://d-fault.nl/files/DNSResolverCom ... .3.exe.zip
" I will initiate self-destruct. " — IG-11.
Re: Hardening hMailServer - The ongoing saga!
Post by SorenR » 2019-01-28 17:12
Face it, GreyListing is brilliant - but it sucks when you are in a hurry to receive mail.
Adding delays to deter the "always busy" SPAM sender is known as SMTP Transaction Delays and it simply means waiting a number of seconds before answering the sender. In the SPAM world, time is money and spammers do NOT like to wait, so they cut their losses short and move on to the next victim. This is actually a primitive form of teergrubing. http://altlasten.lutz.donnerhacke.de/mi ... be.en.html
In this example we expect all communication with *WORLD* is done on SMTP port 25.
Option Explicit
'   COM authentication
Private Const PASSWORD = "########"
Function Wait(sec)
      .Run "timeout /T " & Int(sec), 0, True       '   Use with Windows 7/2003/2008 or later
'     .Run "sleep -m " & Int(sec * 1000), 0, True  '   Use with Windows 2003 Resource Kit
'     .Run "powershell Start-Sleep -Milliseconds " & Int(sec * 1000), 0, True
Sub OnClientConnect(oClient)
   '   Filter out "impatient" servers. Alternative to GreyListing.
Sub OnHELO(oClient)
'*  ********** SPAM test: DNSBlackLists, HeloHost, MXRecords, SPF
'*  ********** SPAM test: SURBL, DKIM, SpamAssassin
'* Sub OnAcceptMessage(oClient, oMessage)
'* End Sub
'*  ********** Saving EML to DATA
'* Sub OnDeliveryStart(oMessage)
'* End Sub
'*  ********** Antivirus check, Global rules
'* Sub OnDeliverMessage(oMessage)
'* End Sub
'*  ********** Local rules, Message delivered to recipient(s)
'* Sub OnDeliveryFailed(oMessage, sRecipient, sErrorMessage)
'* End Sub
'* Sub OnExternalAccountDownload(oFetchAccount, oMessage, sRemoteUID)
'* End Sub
'* Sub OnBackupFailed(sReason)
'* End Sub
'* Sub OnBackupCompleted()
'* End Sub
'* Sub OnError(iSeverity, iCode, sSource, sDescription)
'* End Sub
'********** END        **********
NOTE:
Post by SorenR » 2019-01-28 17:29
The majority of us run small installations serving only a handfull domains and/or friends and family. Installing expensive firewalls with IDS capabilities to monitor unauthorised login attempts and/or suddenly finding yourself being brute force attacked can be scary.
One solution is to ONLY allow clients accessing from a well-defined realm.
In this example access is only granted to 3 countries (not that there are no villains im my country ;-) ) namely Denmark (dk), Greenland (gl) and Faroe Islands (fo).
The country codes used are ISO standard.
I acknowledge that there may be some challenges when clients need to access mail from OUTSIDE the realm. I have for this purpose installed WEBMAIL to enable clients access to their email worldwide.
Another solution is to use VPN to gain access to mail.
Option Explicit
Function GeoLookup(strIP) : GeoLookup = "zz"
   Dim a, element, group, strLookup
   a = Split(strIP, ".")
      strLookup = .TXT(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".zz.countries.nerd.dk")
   If Trim(strLookup) = "" Then
      EventLog.Write( "- GeoLookup(" & strIP & ") = " & GeoLookup )
      Exit Function
   group = Split(strLookup, vbCrLf)
   If UBound(group) > 0 Then
      For Each element In group
         If (Trim(element) <> "") Then EventLog.Write( "- GeoLookup(" & strIP & ") = " & element )
      GeoLookup = group(0)
   '   Exclude local LAN from test
   '   Only allow non-SMTP connect from "Rigsfællesskabet"/"Naalagaaffeqatigiit"/"Ríkisfelagsskapurin" = The Danish Realm.
   '   zz = N/A, dk = Denmark, gl = Greenland, fo = Faroe Islands
   If (oClient.Port <> 25) Then
      If (InStr("|dk|gl|fo|", GeoLookup(oClient.IPAddress)) = 0) Then
         Result.Value = 1
         Exit Sub
'* Sub OnHELO(oClient)
'* End Sub
'* Sub OnSMTPData(oClient, oMessage)
'* End Sub
'* End Sub
'* End Sub
'* End Sub
'* End Sub
'* End Sub
'* End Sub
'* End Sub
'* End Sub
NOTE:
Post by SorenR » 2019-01-28 17:57
This is an attempt to create some form of IDS (Intrusion Detection System) into hMailServer. It works by using the system database of hMailServer - in this case MySQL.
Functionality:
Case A.
1 - When server connect on port 25, the IP address is added to the IDS registry.
2 - When this connection produces an email, the IP address is removed from IDS registry.
3 - A handler will load data from the database and determine if a BAN on the IP address is needed.
Case B.
1 - A connection from outside the defined Realm is detected, the IP address is added to the IDS registry
2 - A handler will load data from the database and BAN the IP address.
The code is split into two in order to put as little stress on hMailServer mail functionality as possible.
The file Handler.vbs is executed by Windows Scheduler every 1 minute and will do the banning and housekeeping of the IDS registry.
Banning criteria:
1: Violation of Realm = immediate BAN
2: 3 "half-connections" within 180 minutes.
File: EventHandlers.vbs
Option Explicit
'********** hMailServer IDS Client Code (MySQL)        **********
Private Const idsTable = "hm_ids"
'   DRIVER={MySQL ODBC 5.3 Unicode Driver};Server=localhost;Port=3306;Database=%idsdb%;Uid=%idsuid%;Pwd=%idspwd%;Option=3;
'   Table:   CREATE TABLE %idsTable% (
'                   timestamp DATETIME,
'                   ipaddress VARCHAR (192) PRIMARY KEY,
'                   port      INTEGER,
'                   hits      INTEGER);
Function idsAddIP(sIPAddress, iPort)
   strSQL = "INSERT INTO " & idsTable & " (timestamp,ipaddress,port,hits) VALUES (NOW(),'" & sIPAddress & "'," & iPort & ",1) ON DUPLICATE KEY UPDATE hits=(hits+1),timestamp=NOW();"
   Call oDB.ExecuteSQL(strSQL)
Function idsDelIP(sIPAddress)
   strSQL = "DELETE FROM " & idsTable & " WHERE ipaddress = '" & sIPAddress & "';"
Function GetDatabaseObject()
   Set GetDatabaseObject = oApp.Database
      Exit Function
         '   Add unauthorized access to IDS registry
         Call idsAddIP(oClient.IPAddress, oClient.Port)
         Result.Value = 1
         Exit Sub
   '   Only test SMTP traffic on defined ports 25, 587 and 465.
   '   Register IP address in IDS registry.
   If (InStr("|25|587|465|", oClient.Port) > 0) Then Call idsAddIP(oClient.IPAddress, 0)
'* End Sub
'* End Sub
   '   Unregister IP address from IDS registry
   Call idsDelIP(oClient.IPAddress)
'* End Sub
'* End Sub
'* End Sub
'* End Sub
'* End Sub
'* End Sub
'* End Sub
File: Handler.vbs
Option Explicit
'   MySQL
Private Const DBNAME = "hmailserver"
Private Const DBUID = "hmsuser"
Private Const DBPW = "########"
Private Const idsHits = 3
Private Const idsMinutes = 180
Dim idsDBDrv : idsDBDrv = "DRIVER={MySQL ODBC 5.3 Unicode Driver};Database="&DBNAME&";Uid="&DBUID&";Pwd="&DBPW&";Option=3;"
'                   port      INTEGER,
'                   hits      INTEGER);
'********** Classes        **********
Class LogWriter
   Private m_oApp, m_LogID, m_LogFile, m_LogType, m_LogDir
   Private i, t, temp, strDay, strMonth, strTime, strLogFile, strLogDate
   Private Sub Class_Initialize()
      Set m_oApp = CreateObject("hMailServer.Application")
      Call m_oApp.Authenticate(ADMIN, PASSWORD)
      m_LogFile = "LogWriter"
      m_LogType = "M"
      m_LogDir = m_oApp.Settings.Directories.LogDirectory
      m_LogID = CStr(m_oApp.Status.ProcessedMessages)
   Private Sub Class_Terminate()
      '   Termination code goes here.
   Public Property Let LogFile(strFile)
      m_LogFile = Trim(strFile)
   End Property
   Public Property Let LogDir(strDir)
      If (Right(strDir, 1) = "\") Then
         m_LogDir = Trim(Left(strDir, Len(strDir) - 1))
         m_LogDir = Trim(strDir)
   End Property
   Public Property Let LogType(strType)
      m_LogType = Trim(strType)
   End Property
   Public Function Wait(sec)
         .Run "timeout /T " & Int(sec), 0, True       ' Windows 7/2003/2008 or later
'        .Run "sleep -m " & Int(sec * 1000), 0, True  ' Windows 2003 Resource Kit
   Public Function OpenFile(strPath)
      Const Append = 8
      Const Unicode = -1
         Dim oFile
         For i = 0 To 30
            On Error Resume Next
            If Not (Err.Number = 70) Then
               Set OpenFile = oFile
               On Error Goto 0
               Exit For
            On Error Goto 0
            Wait(1)
      If (Err.Number = 70) Then
         EventLog.Write( "ERROR: VBScript Class LogWriter" )
         Err.Clear
      ElseIf (Err.Number <> 0) Then
         EventLog.Write( "ERROR: VBScript Class LogWriter : Function OpenFile" )
         Err.Clear
   Public Function Write(strText)
      t = Timer
      temp = Int(t)
      strMonth = DatePart("yyyy",Date) & "-" & Right("0" & DatePart("m",Date), 2)
      strDay = strMonth & "-" & Right("0" & DatePart("d",Date), 2)
      strTime = Right("0"  & Hour(Now),   2) & ":" &_
                Right("0"  & Minute(Now), 2) & ":" &_
                Right("0"  & Second(Now), 2) & "." &_
                Right("00" & (Int((t-temp) * 1000)), 3)
      strLogDate = strDay & " " & strTime
      If (m_LogType = "M") Then
         strLogFile = m_LogDir & "\" & m_LogFile & "_" & strMonth & ".log"
         strLogFile = m_LogDir & "\" & m_LogFile & "_" & strDay & ".log"
      With OpenFile(strLogFile)
         .WriteLine(m_LogID & vbTab & Chr(34) & strLogDate & Chr(34) & vbTab & Chr(34) & strText & Chr(34))
         .Close
      Write = Err.Number
End Class
         .LowerIP = sIPAddress
         .UpperIP = sIPAddress
         .Priority = 20
         .Expires = True
         .Save
      AutoBan = True
   On Error Goto 0
'********** CODE        **********
Dim EventLogX : Set EventLogX = New LogWriter
'   Name of the logfile.
'   Default is monthly logs, for daily logs add: EventLogX.LogType = "D"
EventLogX.LogFile = "handler"
Dim strPort
oConn.Open idsDBDrv
If oConn.State <> 1 Then
   EventLog.Write( "Handler - ERROR: Could not connect to database" )
   WScript.Quit 1
Set oRecord = oConn.Execute("SELECT * FROM " & idsTable & " WHERE hits > " & idsHits & " AND port = 0;")
If Err.Number <> 0 Then
   EventLog.Write( "Handler - ERROR: Table " & idsTable & " does not exist!" )
   WScript.Quit 1
If Not oRecord.BOF And Not oRecord.EOF Then
   While Not oRecord.EOF
      EventLogX.Write( "Wohoo... IPAddress: " & oRecord("ipaddress") & " Port: " & oRecord("port") & " Hits: " & oRecord("hits") )
      If (DateDiff("n", oRecord("timestamp"), Now()) < idsMinutes) Then
         If AutoBan(oRecord("ipaddress"), "IDS", 7, "d") Then _
            EventLogX.Write( "AutoBan(" & oRecord("ipaddress") & ", IDS, 7, d)" )
      oConn.Execute "DELETE FROM " & idsTable & " WHERE ipaddress = '" & oRecord("ipaddress") & "';"
      oRecord.MoveNext
   Wend
Set oRecord = oConn.Execute("SELECT * FROM " & idsTable & " WHERE hits > " & idsHits & " AND port > 0;")
         strPort = Trim(Mid("SMTP IMAP SMTPSSUBM IMAPS", InStr("25   143  465  587  993  ", oRecord("port")), 5))
         If AutoBan(oRecord("ipaddress"), "GEOBLOCK - " & strPort, 7, "d") Then _
            EventLogX.Write( "AutoBan(" & oRecord("ipaddress") & ", GEOBLOCK - " & strPort & ", 7, d)" )
      oRecord.MoveNext
   Wend
oConn.Execute "DELETE FROM " & idsTable & " WHERE DATE_ADD(timestamp, INTERVAL 1 DAY) < NOW();"
oConn.Close
NOTE:
Post by SorenR » 2019-01-28 18:17
Well... Since this is all Open Source I thought I might as well disclose it all :mrgreen:
All files have been annonymized and scrubbed so I cannot guarantee that it all works (disclaimer: use at your own risc!).
- EventHandlers.vbs goes into .\hMailServer\Events
- Handler.vbs is called by Windows Scheduler every 1 minute
- Check-State.vbs is called by Windows Scheduler every 30 minutes
- RunBackup.vbs is called by Windows Scheduler every sunday at 5 AM
- hMailServer.xml goes into .\hMailServer\Events and contains a dynamic list of RegEx expressions used to 1: reject mail, 2: blacklist mail and 3: whitelist mail.
The XML handling was added only a few days ago and may/may not need adjusting at some point in the future.
File: EvenHandlers.vbs
Option Explicit
Private Const XMLDATA = "hMailServer.xml"
'********** Includes        **********
'* Include("C:\hMailServer\Events\VbsJson.vbs")
'* Function Include(sInstFile)
'*    Dim f, s, oFSO
'*    Set oFSO = CreateObject("Scripting.FileSystemObject")
'*    On Error Resume Next
'*    If oFSO.FileExists(sInstFile) Then
'*       Set f = oFSO.OpenTextFile(sInstFile)
'*       s = f.ReadAll
'*       f.Close
'*       ExecuteGlobal s
'*    End If
'*    On Error Goto 0
'*    Set f = Nothing
'*    Set oFSO = Nothing
'* End Function
Class LogWriter
      m_LogType = "M"
   End Property
   End Property
   End Property
      Const Append = 8
      Const Unicode = -1
         Dim oFile
         For i = 0 To 30
               On Error Goto 0
               Exit For
            On Error Goto 0
            Wait(1)
         Err.Clear
         Err.Clear
      t = Timer
      temp = Int(t)
         .Close
      Write = Err.Number
End Class
'                   port      INTEGER,
'                   hits      INTEGER);
Function Wait(sec)
Function LockFile(strPath)
   Const Append = 8
   Const Unicode = -1
      Dim oFile, i
      For i = 0 To 30
            Set LockFile = oFile
            On Error Goto 0
            Exit For
         On Error Goto 0
         Wait(1)
      Err.Clear
      Err.Clear
      .Pattern = strRegEx
      .Global = False
      .MultiLine = True
      .IgnoreCase = True
      .Pattern = strRegEx
      .Global = bGlobal
      .MultiLine = True
      .IgnoreCase = True
Function IsSnowShoe(strIP) : IsSnowShoe = False
   Dim a, strLookup
      strLookup = .DNSLookup(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".sbl.spamhaus.org")
   If (strLookup = "127.0.0.3") Then IsSnowShoe = True
      Exit Function
   With LockFile(oApp.Settings.Directories.TempDirectory & "\autoban.lck")
            .Priority = 20
            .Expires = True
            .Save
         AutoBan = True
      On Error Goto 0
      .Close
Function isBanned(oMessage) : isBanned = False
   Dim strRegEx, i, a, Match, Matches, strIP, strLowerIP, strUpperIP, strReceivedBy
   '   Backup-MX/Relay-Host.
   strReceivedBy = "backup-mx.post.tele.dk"
   '   RegEx to locate IPv4 address in string.
   strRegEx = "(?:[0-9]{1,3}\.){3}[0-9]{1,3}"
      If (oMessage.Headers(i).Name = "Received") Then
         If Lookup("by " & strReceivedBy, oMessage.Headers(i).Value) Then
            Set Matches = oLookup(strRegEx, oMessage.Headers(i).Value, False)
            For Each Match In Matches
               oMessage.HeaderValue("X-Envelope-IPAddress") = Match.Value
               strIP = Match.Value
               For a = 0 To oApp.Settings.SecurityRanges.Count-1
                  If (oApp.Settings.SecurityRanges.Item(a).Priority = 20) Then
                     strLowerIP = oApp.Settings.SecurityRanges.Item(a).LowerIP
                     strUpperIP = oApp.Settings.SecurityRanges.Item(a).UpperIP
                     If (strUpperIP >= strIP >= strLowerIP) Then
                        EventLog.Write( "Wohoo (isBanned), " & strIP & " in range of " & strLowerIP & "-" & strUpperIP )
                        isBanned = True
                        Exit Function
            Exit Function
Function LoadXML(XMLFile)
   Dim oXML : Set oXML = CreateObject("MSXML2.DOMDocument")
   oXML.Load(oApp.Settings.Directories.EventDirectory & "\" & XMLFile)
   If oXML.parseError <> 0 Then
      EventLog.Write( "XML ERROR - errorCode - " & oXML.parseError.errorCode ) ' Returns a long integer error code
      EventLog.Write( "XML ERROR - reason    - " & oXML.parseError.reason )    ' Returns a string explaining the reason for the error
      EventLog.Write( "XML ERROR - line      - " & oXML.parseError.line )      ' Returns a long integer representing the line number for the error
      EventLog.Write( "XML ERROR - linePos   - " & oXML.parseError.linePos )   ' Returns a long integer representing the line position for the error
      EventLog.Write( "XML ERROR - srcText   - " & oXML.parseError.srcText )   ' Returns a string containing the line that caused the error
      EventLog.Write( "XML ERROR - url       - " & oXML.parseError.url )       ' Returns the url pointing the loaded document
      EventLog.Write( "XML ERROR - filePos   - " & oXML.parseError.filePos )   ' Returns a long integer file position of the error
   Set LoadXML = oXML
Function LoadXMLNode(oXML, MyNode) : LoadXMLNode = ""
   Dim Match, Matches, strTXT
   Set Matches = oXML.selectNodes(MyNode)
   strTXT = ""
      strTXT = strTXT & Match.text & "|"
   If (Trim(strTXT) <> "") Then
      LoadXMLNode = Left(strTXT,Len(strTXT)-1)
      EventLog.Write( "ERROR: Empty string from LoadXMLNode(oXML, " & MyNode & ")" )
'********** Subroutines        **********
Sub XEnvelope(oMessage)
   Dim i, strEnvelope1, strEnvelope2
      If (i = 0) Then
         strEnvelope1 = oMessage.Recipients(i).Address
         strEnvelope2 = oMessage.Recipients(i).OriginalAddress
         strEnvelope1 = strEnvelope1 & ", " & oMessage.Recipients(i).Address
         strEnvelope2 = strEnvelope2 & ", " & oMessage.Recipients(i).OriginalAddress
   oMessage.HeaderValue("X-Envelope-To") = strEnvelope1
   oMessage.HeaderValue("X-Envelope-OriginalTo") = strEnvelope2
Sub SPAMList(oMessage, strMatch)
   Dim i
   If (oMessage.HeaderValue("X-hMailServer-Spam") = "YES") Then
      i = CInt(oMessage.HeaderValue("X-hMailServer-Reason-Score"))
      i = 0
   oMessage.HeaderValue("X-hMailServer-Reason-0") = "SPAMlisted - (Score: 5)"
   oMessage.HeaderValue("X-hMailServer-Reason-Score") = 5 + i
   oMessage.HeaderValue("X-Blacklist-RegEx") = strMatch
Sub WhiteList(oMessage, strMatch)
   Dim i
      oMessage.HeaderValue("X-Whitelist-RegEx") = strMatch
      oMessage.Headers.ItemByName("X-hMailServer-Spam").Delete
      For i = 0 To 10
         If (oMessage.HeaderValue("X-hMailServer-Reason-" & i) <> "") Then _
            oMessage.Headers.ItemByName("X-hMailServer-Reason-" & i).Delete
      oMessage.Headers.ItemByName("X-hMailServer-Reason-Score").Delete
Sub RansomWare(oMessage)
   Dim i
      i = 0
   oMessage.HeaderValue("X-hMailServer-Reason-0") = "RansomWare - (Score: 5)"
   oMessage.Subject = ":!: RansomWare :!: " & oMessage.Subject
   '   Exclude Backup-MX & local LAN from test
   If (Left(oClient.IPAddress, 10) = "80.160.77.") Then Exit Sub
         Result.Value = 1
         Exit Sub
Sub OnHELO(oClient)
   Dim oXML : Set oXML = LoadXML(XMLDATA)
   Dim strRegEx, Match, Matches
   '   SnowShoe SPAM detection
      Result.Value = 2
      Result.Message = "5.7.1 CODE01 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means."
      Exit Sub
   '   FIX for known anomalities ...
   strRegEx = "^(VVS-WEB)[0-9]{2}(\.localdomain)$"
   If Lookup(strRegEx, oClient.HELO) Then Exit Sub
   '   Deny servers with specific HELO/EHLO greetings
   strRegEx = LoadXMLNode(oXML, "//Reject/HELO")
      Result.Value = 2
      Result.Message = "5.7.1 CODE02 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means."
      Call AutoBan(oClient.IPAddress, "BLACKLIST - " & oClient.HELO, 7, "d")
      Exit Sub
   '   Validate HELO/EHLO greeting
      Result.Value = 2
      Result.Message = "5.7.1 CODE03 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means."
      Call AutoBan(oClient.IPAddress, "Bad HELO - " & oClient.HELO, 7, "d")
      Exit Sub
   Dim strRegEx, Match, Matches, i
   Dim i, a, strRegEx, Match, Matches
   '   Placeholder for senders IP Address either direct or via Backup-MX
   oMessage.HeaderValue("X-Envelope-IPAddress") = oClient.IPAddress
   strRegEx = "^(80\.160\.77\.)[0-9]{1,3}$|^(192\.168\.0\.)[0-9]{1,3}$"
   If Not Lookup(strRegEx, oClient.IPAddress) Then
      '   Cleanup IDS registry
   '   Exclude authenticated users test
   If (oClient.Username <> "") Then Exit Sub
   '   Banned sender via Backup-MX ?
      If isBanned(oMessage) Then
         Result.Value = 2
         Result.Message = "5.7.1 CODE08 The SMTP service on IP address (" & oMessage.HeaderValue("X-Envelope-IPAddress") & ") is not welcome here."
         Exit Sub
   '   Reject "List-Unsubscribe:"
   strRegEx = LoadXMLNode(oXML, "//Reject/List-Unsubscribe")
   Set Matches = oLookup(strRegEx, oMessage.HeaderValue("List-Unsubscribe"), False)
      Result.Value = 2
      Result.Message = "5.7.1 CODE09 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means."
      Exit Sub
   '   Reject "X-Envelope-From:"
   strRegEx = LoadXMLNode(oXML, "//Reject/X-Envelope-From")
   Set Matches = oLookup(strRegEx, oMessage.FromAddress, False)
      Result.Value = 2
      Result.Message = "5.7.1 CODE04 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means."
      Exit Sub
   '   Reject "From:"
   strRegEx = LoadXMLNode(oXML, "//Reject/From")
   Set Matches = oLookup(strRegEx, oMessage.From, False)
      Result.Value = 2
      Result.Message = "5.7.1 CODE05 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means."
      Exit Sub
   '   Reject "Subject:"
   strRegEx = LoadXMLNode(oXML, "//Reject/Subject")
   If (oMessage.HeaderValue("X-Blacklist-RegEx") = "") Then
      Set Matches = oLookup(strRegEx, oMessage.Subject, False)
         Result.Value = 2
         Result.Message = "5.7.1 CODE06 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means."
         Exit Sub
   '   Reject "Body:"
   strRegEx = LoadXMLNode(oXML, "//Reject/Bodytxt")
   If Lookup(strRegEx, oMessage.Body) Or Lookup(strRegEx, oMessage.HTMLBody) Then
      Result.Value = 2
      Result.Message = "5.7.1 CODE07 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means."
      Exit Sub
   '   RansomWare - Body text/URL check
   strRegEx = LoadXMLNode(oXML, "//Ransomeware/Bodytxt")
   If Lookup(strRegEx, oMessage.Body) Or Lookup(strRegEx, oMessage.HTMLBody) Then Call RansomWare(oMessage)
   '   Additional SPAM processing
   Dim Done : Done = False
   If (oMessage.HeaderValue("X-hMailServer-Spam") = "YES") Then Done = True
   Do Until Done
      '   Blacklist IP Range
      '   http://www.analyticsmarket.com/freetools/ipregex
      '   216.82.240.0 - 216.82.255.255 = MessageLabs Inc. (Symantec Inc.)
      '   ^216\.82\.(2(4[0-9]|5[0-5]))\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$
      strRegEx = LoadXMLNode(oXML, "//Blacklist/IPRange")
      Set Matches = oLookup(strRegEx, oClient.IPAddress, False)
         Call SPAMList(oMessage, "BlackList oClient.IPAddress: Value '" & Match.Value & "'")
         Exit Do
      '   Blacklist "X-Envelope-From:"
      strRegEx = LoadXMLNode(oXML, "//Blacklist/X-Envelope-From")
         Call SPAMList(oMessage, "BlackList oMessage.FromAddress: Value '" & Match.Value & "'")
         Exit Do
      '   Blacklist "From:"
      strRegEx = LoadXMLNode(oXML, "//Blacklist/From")
         Call SPAMList(oMessage, "BlackList oMessage.From: Value '" & Match.Value & "'")
         Exit Do
      '   Blacklist "Subject:"
      strRegEx = LoadXMLNode(oXML, "//Blacklist/Subject")
         Call SPAMList(oMessage, "BlackList oMessage.Subject: Value '" & Match.Value & "'")
         Exit Do
      '   Blacklist Body - iPhone SPECIAL
      strRegEx = LoadXMLNode(oXML, "//Blacklist/Bodytxt")
      Set Matches = oLookup(strRegEx, oMessage.Body, False)
         Call SPAMList(oMessage, "BlackList oMessage.Body: Value '" & Match.Value & "'")
         Exit Do
      ' <!-- ... -->   PHP: "(<!--[^>]*-->)"      JavaScript: "(<!--[\s\S]*?-->)"
      ' /*   ...  */   PHP: "(\/\*)[^>]*(\*\/)"   JavaScript: "(\/\*)[\s\S]*?(\*\/)"
      ' <!--[\\s\\S]*?(?:-->)?<!---+>?|<!(?![dD][oO][cC][tT][yY][pP][eE]|\\[CDATA\\])[^>]*>?|<[?][^>]*>?
      Dim strHTMLBody : strHTMLBody = oMessage.HTMLBody
         .Pattern = "(\/\*[\s\S]*?\*\/)|(<[\s\S]*?>)"
         .Global = True
         .MultiLine = True
         .IgnoreCase = True
         strHTMLBody = .Replace(strHTMLBody, "")
      Set Matches = oLookup(strRegEx, strHTMLBody, False)
         Call SPAMList(oMessage, "BlackList oMessage.HTMLBody: Value '" & Match.Value & "'")
         Exit Do
      Done = True
   Loop
      '   Whitelist "X-Envelope-From:"
         strRegEx = LoadXMLNode(oXML, "//Whitelist/X-Envelope-From")
            Call WhiteList(oMessage, "WhiteList oMessage.FromAddress: Value '" & Match.Value & "'")
      '   Whitelist "From:"
         strRegEx = LoadXMLNode(oXML, "//Whitelist/From")
            Call WhiteList(oMessage, "WhiteList oMessage.From: Value '" & Match.Value & "'")
   '   Add X-Envelope... headers
   Call XEnvelope(oMessage)
'* End Sub
'* End Sub
'* End Sub
'* End Sub
   If (oApp.ServerState = 1) Then
      EventLog.Write( "" )
      EventLog.Write( "EventHandlers: Starting server AFTER backup FAILED! Error: " & sReason )
      Call oApp.Start
      EventLog.Write( "EventHandlers: Starting server after backup COMPLETED." )
      Call oApp.Start
   EventLogX.LogFile = "error"
   EventLogX.Write( "" )
   EventLogX.Write( "iSeverity: " & iSeverity )
   EventLogX.Write( "iCode: " & iCode )
   EventLogX.Write( "sSource: " & sSource )
   EventLogX.Write( "sDescription: " & sDescription )
'********** hMailServer Rules        **********
   ' Rules test ...
   ' True: Mon-Thu 00:00 - 06:59 & 17:00 - 23:59
   ' (?i:^.*\;.(Mon|Tue|Wed|Thu).*.(([0][0-6])|([1][7-9])|([2][0-3]))\:.*$)
   ' True: Fri 00:00 - 06:59 & 16:00 - 23:59
   ' (?i:^.*\;.(Fri).*.(([0][0-6])|([1][6-9])|([2][0-3]))\:.*$)
   ' True: Sat-Sun
   ' (?i:^.*\;.(Sat|Sun).*$)
   ' True: Mon-Fri 00:00 - 06:59 & 17:00 - 23:59 & Sun & Sat
   ' (?i:^(.*\;.)((Sat|Sun)|((Mon|Tue|Wed|Thu|Fri)(.*\x20)(([0][0-6])|([1][7-9])|([2][0-3]))\:))(.*)$)
   ' True: 25 Dec 07:00 - 16:59
   ' (?i:^.*\,.(25 Dec).*.(([0][7-9])|([1][0-6]))\:.*$)
Sub Unsubscribe(oMessage)
   ' RFC6068 The 'mailto' URI Scheme: subject, cc, bcc, in-reply-to, body etc.. ?first &second &third etc...
   Const            m_To = "Donald J. Trump"
   Const        m_Sender = "Wile E. Coyote"
   Const m_SenderAddress = "wile.e.coyote@acme.inc"
   Dim a, b, strRegEx, Match, Matches, sMailTo, sURL, m_Subject, m_Body, doMail, doURL
   strRegEx = "^[0-1]:[0-1]$"
   If Lookup(strRegEx, oMessage.HeaderValue("X-hMailServer-Unsubscribe")) Then
      a = Split(oMessage.HeaderValue("X-hMailServer-Unsubscribe"), ":")
      doMail = a(0)
      doURL = a(1)
      doMail = True
      doURL = True
   If doMail Then
      strRegEx = "([^\<]*?)(mailto:[\s\S]*?)(?=\>)"
      Set Matches = oLookup(strRegEx, oMessage.HeaderValue("List-Unsubscribe"), True)
         sMailTo = Mid(Trim(Match.Value), 8)
         a = Split(sMailTo, "?")
         If (UBound(a) > 0) Then
            b = Split(a(1), "&")
            If (InStr(1, b(0), "subject=", 1) > 0) Then m_Subject = Replace(b(0), "subject=", "")
            If (InStr(1, b(0), "body=", 1) > 0) Then m_Body = Replace(b(0), "body=", "")
            If (UBound(b) > 0) Then
               If (InStr(1, b(1), "subject=", 1) > 0) Then m_Subject = Replace(b(1), "subject=", "")
               If (InStr(1, b(1), "body=", 1) > 0) Then m_Body = Replace(b(1), "body=", "")
            .From = Chr(34) & m_Sender & Chr(34) & " <" & m_SenderAddress & ">"
            .FromAddress = m_SenderAddress
            .AddRecipient a(0), a(0)
            .AddRecipient m_Sender, m_SenderAddress
            .HeaderValue("To") = Chr(34) & m_To & Chr(34) & " <" & a(0) & ">"
            .HeaderValue("CC") = Chr(34) & m_Sender & Chr(34) & " <" & m_SenderAddress & ">"
            .Subject = "Unsubscribe"
             If Not (m_Subject = Empty) Then .Subject = m_Subject
            .Body = "Unsubscribe"
             If Not (m_Body    = Empty) Then .Body = m_Body
            .Save
            EventLog.Write( "ERROR: Sub Unsubscribe(oMessage)" )
            Err.Clear
            Exit Sub
   If doURL Then
      strRegEx = "([^\<]*?)((http|https):[\s\S]*?)(?=\>)"
         sURL = Trim(Match.Value)
         With CreateObject("MSXML2.ServerXMLHTTP.6.0")
            .setoption(2) = (.getoption(2) & " - SXH_SERVER_CERT_IGNORE_ALL_SERVER_ERRORS")
            .open "GET", sURL, False
            .setrequestheader "User-Agent", "online link validator (http://www.dead-links.com/)"
            .send ("")
         On Error Goto 0
            Err.Clear
            Exit Sub
NOTE:
File: Handler.vbs
Option Explicit
'   MySQL
'                   port      INTEGER,
'                   hits      INTEGER);
Class LogWriter
      m_LogType = "M"
   End Property
   End Property
   End Property
      Const Append = 8
      Const Unicode = -1
         Dim oFile
         For i = 0 To 30
               On Error Goto 0
               Exit For
            On Error Goto 0
            Wait(1)
         Err.Clear
         Err.Clear
      t = Timer
      temp = Int(t)
         .Close
      Write = Err.Number
End Class
         .Priority = 20
         .Expires = True
         .Save
      AutoBan = True
   On Error Goto 0
Dim strPort
oConn.Open idsDBDrv
   WScript.Quit 1
   WScript.Quit 1
      oRecord.MoveNext
   Wend
      oRecord.MoveNext
   Wend
oConn.Close
File: Check-State.vbs
Option Explicit
Class LogWriter
      m_LogType = "M"
   End Property
   If Right(strDir, 1) = "\" Then
   End Property
   End Property
      Const Append = 8
      Const Unicode = -1
         Dim oFile
         For i = 0 To 30
               On Error Goto 0
               Exit For
            On Error Goto 0
            Wait(1)
         Err.Clear
         Err.Clear
      t = Timer
      temp = Int(t)
         .Close
      Write = Err.Number
End Class
Dim FSO : Set FSO = CreateObject("Scripting.FileSystemObject")
EventLogX.LogFile = "checkstate"
If oApp.ServerState = 1 Then
   If (FSO.FolderExists(oApp.Settings.Backup.Destination & "\DataBackup")) Then
      EventLogX.Write("CheckState: Server is currently doing backup...")
      EventLogX.Write("CheckState: Server was stopped for no reason, starting...")
      Call oApp.Start
File: RunBackup.vbs
Option Explicit
Function Wait(sec)
'********** RunBackup        **********
Dim LoopCount : LoopCount = 0
EventLog.Write("")
   If FSO.FolderExists(oApp.Settings.Backup.Destination & "\DataBackup") Then
      EventLog.Write("RunBackup: Server is currently doing backup...")
      EventLog.Write("RunBackup: Server is stopped for no reason, aborting backup...")
   EventLog.Write("RunBackup: Stopping server for Backup")
   Call oApp.Stop
   EventLog.Write("RunBackup: Waiting for server to stop")
   Do While (oApp.ServerState = 4 And LoopCount < 6)
      EventLog.Write("RunBackup: Waiting...")
      Wait(5)
      LoopCount = LoopCount + 1
   Loop
   If (LoopCount > 5) Then EventLog.Write("RunBackup: Something went wrong - timeout waiting for server to stop.")
   Call oApp.BackupManager.StartBackup()
   EventLog.Write("RunBackup: Backup started")
'* '   Triggers for EventHandlers.vbs
'*    Dim oApp : Set oApp = CreateObject("hMailServer.Application")
'*    Call oApp.Authenticate(ADMIN, PASSWORD)
'*    If (oApp.ServerState = 1) Then
'*       EventLog.Write( "" )
'*       EventLog.Write( "EventHandlers: Starting server AFTER backup FAILED! Error: " & sReason )
'*       Call oApp.Start
'*    End If
'* End Sub
'*       EventLog.Write( "EventHandlers: Starting server after backup COMPLETED." )
'*       Call oApp.Start
'*    End If
'* End Sub
File: hMailServer.xml
<?xml version="1.0" encoding="utf-8" standalone="yes"?>
<Parameters>
  <Reject>
    <HELO>^(\[123\.123\.123\.123\])$<!--This is your public IP address.--></HELO>
    <HELO>^(acme\.inc)$<!--This is your public DOMAIN.--></HELO>
    <HELO>^(mx\.acme\.inc)$<!--This is your public SERVER address.--></HELO>
    <HELO>^(.*\.[a-z]{4,})$<!--WILL MATCH ANY 4+ LETTER TLD, USE WITH CAUTION!--></HELO>
    <HELO>(0\.0\.0\.0)</HELO>
    <HELO>(127(?:\.[0-9]{1,3}){3})</HELO>
    <List-Unsubscribe>(\&lt;http:\/\/(.*)\/unsubscribe\.php\?M=(.*)&amp;C=(.*)&amp;L=(.*)&amp;N=(.*)\&gt;)</List-Unsubscribe>
    <X-Envelope-From>^(.*\@dcs-dz\.com)$</X-Envelope-From>
    <X-Envelope-From>^(.*\@dozura\.com)$</X-Envelope-From>
    <X-Envelope-From>^(.*\@danzamor\.com)$</X-Envelope-From>
    <X-Envelope-From>^(.*\@twoomail\.com)$</X-Envelope-From>
    <X-Envelope-From>^(.*\@vrshoesale\.com)$</X-Envelope-From>
    <X-Envelope-From>^(.*\@danmarkmail\.com)$</X-Envelope-From>
    <X-Envelope-From>^(.*\@epsp-telagh\.com)$</X-Envelope-From>
    <X-Envelope-From>(\.tw|\.bid|\.kim|\.men|\.top|\.win|\.xyz|\.zip)$</X-Envelope-From>
    <From>(Sweetme)|(Kira Johns)|(July Girl)|(Hot Mama)|(Little Miss)</From>
    <From>(Baby Boobs)|(Booby Girl)|(Booby Booms)</From>
    <From>(\.tw|\.bid|\.kim|\.men|\.top|\.win|\.xyz|\.zip)(|\&gt;)$</From>
    <Subject>^(yo|hi|sup|hello|greets|hey t?here)(!?)(.?)(8?-?\)?)?$</Subject>
    <Bodytxt>(\.xyz\/)</Bodytxt>
    <Bodytxt>(thisemailwillchangeyourlife)</Bodytxt>
    <Bodytxt>(Please sign the contract)</Bodytxt>
  </Reject>
  <Blacklist>
    <X-Envelope-From>^(.*\@.*\.[a-z]{4,})$<!--WILL MATCH ANY 4+ LETTER TLD, USE WITH CAUTION!--></X-Envelope-From>
    <X-Envelope-From>^(return\@.*)$</X-Envelope-From>
    <X-Envelope-From>^(job\@.*)$</X-Envelope-From>
    <X-Envelope-From>^(login@gaijin.net)$</X-Envelope-From>
    <X-Envelope-From>^(.*\@.*bitcoin.*)$</X-Envelope-From>
    <From>(\&lt;.*\@.*\.[a-z]{4,}\&gt;)$<!--WILL MATCH ANY 4+ LETTER TLD, USE WITH CAUTION!--></From>
    <Subject>(Fakta Gavekort)</Subject>
    <Subject>(Vi inviterer dig til at tilslutte dig)</Subject>
    <Subject>(Dette er ikke en reklame)</Subject>
    <Subject>(Blockchain-momentum)</Subject>
    <Subject>(du vil finde rigtig meget brugbar information herinde)</Subject>
    <Subject>(ringede til dig, men du tog den ikke)</Subject>
    <Subject>(Noget helt fantastisk er ved at ske)</Subject>
    <Subject>((iPhone)(\x20(3G|4|5|6|SE|7|8|9|X))?(C|S|R)?(\x20(Plus|Max))?)</Subject>
    <Bodytxt>(Du har fået denne mail tilsendt angående et jobtilbud)</Bodytxt>
    <Bodytxt>(Vi har registreret, at du har et overskydende)</Bodytxt>
    <Bodytxt>(I øjeblikket tildeler vi alle nyopstartede brugere)</Bodytxt>
    <Bodytxt>(Din konto er i risiko for at blive suspenderet)</Bodytxt>
    <Bodytxt>(Vi leder efter en ny person)</Bodytxt>
    <Bodytxt>(Leo Vegas er)</Bodytxt>
    <Bodytxt>(velkomstbonus til din)</Bodytxt>
    <Bodytxt>(beskytte dit kort mod svig)</Bodytxt>
    <Bodytxt>(I have a proposal)</Bodytxt>
    <Bodytxt>(You are receiving this email because you opted in via our website)</Bodytxt>
    <Bodytxt>(Dette er hemmelig information)</Bodytxt>
    <Bodytxt>(Denne information er hemmelig og må ikke deles)</Bodytxt>
    <Bodytxt>((iPhone)(\x20(3G|4|5|6|SE|7|8|9|X))?(C|S|R)?(\x20(Plus|Max))?)</Bodytxt>
    <IPRange>^216\.82\.(2(4[0-9]|5[0-5]))\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$</IPRange>
  </Blacklist>
  <Whitelist>
    <X-Envelope-From>^(bounces\+3390280\-2e2e\-soren\=acme\.inc\@mail\.computerworld\.dk)$</X-Envelope-From>
    <X-Envelope-From>^(bounce-mc\.us(\d)_59848553\.[0-9]{7}\-soren\=acme\.inc\@mail(.*))$</X-Envelope-From>
    <X-Envelope-From>^(bounce-mc\.us(\d)_26104775\.[0-9]{7}\-jane\=acme\.inc\@mail(.*))$</X-Envelope-From>
    <X-Envelope-From>^(bounce-mc\.us(\d)_4390422\.[0-9]{7}\-jane\=acme\.inc\@mail(.*))$</X-Envelope-From>
    <X-Envelope-From>^(bounces\+2437332\-cc95\-benjamin\=acme\.inc\@em\.spotify\.com)$</X-Envelope-From>
    <X-Envelope-From>^(bounces-633600378734211969\@explore\.pinterest\.com)$</X-Envelope-From>
    <X-Envelope-From>^(notification\+)[a-z,0-9,_]{8}(\@facebookmail\.com)$</X-Envelope-From>
    <X-Envelope-From>^(transaction\@notice\.aliexpress\.com)$</X-Envelope-From>
    <X-Envelope-From>^(tracking-noreply\@webshipr\.com)$</X-Envelope-From>
    <X-Envelope-From>^(noreply\@compugroupmedical\.dk)$</X-Envelope-From>
    <X-Envelope-From>^(no-reply\@telia\.crm-ts\.com)$</X-Envelope-From>
    <X-Envelope-From>^(security\@facebookmail\.com)$</X-Envelope-From>
    <X-Envelope-From>^(noreply\@fitnessworld\.com)$</X-Envelope-From>
    <X-Envelope-From>^(metin\@srv\.eatonline\.dk)$</X-Envelope-From>
    <X-Envelope-From>^(clearpass\@sund\.ku\.dk)$</X-Envelope-From>
    <X-Envelope-From>^(mobilprivat\@telia\.dk)$</X-Envelope-From>
    <X-Envelope-From>^(bounce\@gjensidige\.no)$</X-Envelope-From>
    <X-Envelope-From>^(noreply\@postnord\.dk)$</X-Envelope-From>
    <X-Envelope-From>^(info\@email\.dba\.dk)$</X-Envelope-From>
    <X-Envelope-From>^(info\@billigvvs\.dk)$</X-Envelope-From>
    <X-Envelope-From>(\@(email|insideapple)\.apple\.com)$</X-Envelope-From>
    <X-Envelope-From>(\@bounce\.kundemail\.power\.dk)$</X-Envelope-From>
    <X-Envelope-From>(\@bloggersdelight\.dk)$</X-Envelope-From>
    <X-Envelope-From>(\@hk\.dk)$</X-Envelope-From>
    <From>^(Goodreads &lt;no-reply\@mail\.goodreads\.com&gt;)$</From>
    <From>^(EasyPark &lt;no-reply\@easypark\.net&gt;)$</From>
    <From>(support\@patchingprotocol\.com)</From>
    <From>(account-update\@amazon\.com)</From>
    <From>(no-reply\@myunidays\.com)</From>
    <From>(no_reply\@snapchat\.com)</From>
    <From>(help\@epicgames\.com)</From>
    <From>(nabohjaelp\@dkr\.dk)</From>
    <From>(\@email\.bulkpowders\.com)</From>
    <From>(\@id\.apple\.com)</From>
    <From>(\@seas-nve\.dk)</From>
    <From>(\@yousee\.dk)</From>
  </Whitelist>
  <Ransomeware>
    <Bodytxt>(https://dl.dropboxusercontent.com/s/)</Bodytxt>
    <Bodytxt>(https://www.dropbox.com/meta_dl/)</Bodytxt>
  </Ransomeware>
</Parameters>
Post by palinka » 2019-01-28 20:35
Wow this is really awesome stuff. Thank you for sharing all of it! Great job, man!
Post by palinka » 2019-01-28 20:39
One question (for now :wink: ). What is the ransomware bit in hMailServer.xml? They appear to be legit URLs.
Post by SorenR » 2019-01-28 21:01
2019-01-28 20:39
Yes, bad guys use dropbox too :mrgreen:
Never caught one though.
Post by palinka » 2019-05-04 14:26
OK so I finally got around to implementing this stuff. I have basically everything except the IDS stuff. I worked out all my growing pains except for one issue I don't know how to deal with.
Script Error: Source: Microsoft VBScript runtime error - Error: 800A01A8 - Description: Object required: 'oXML' - Line: 315 Column: 3 - Code: (null)"
That corresponds to this:
   Set Matches = oXML.selectNodes(MyNode)      <<<<---------------- LINE 315
   strTXT = ""
Any ideas?
I have Function LoadXML(XMLFile) included, and Private Const XMLFile = "hMailServer.xml" also, as well as RvdH's activex thingy installed.
Post by SorenR » 2019-05-04 20:12
   Dim oXML : Set oXML = CreateObject("MSXML2.DOMDocument")  <=== YOU ARE MISSING THIS !!
   Set LoadXML = oXML
Post by SorenR » 2019-05-04 20:15
Anyways... It has all been slightly changed in the meantime :oops:
My EventHandlers.vbs is not static code for very long. I find other ways to do the same stuff quicker or with less ressources :mrgreen:
Post by palinka » 2019-05-04 20:40
2019-05-04 20:15
I know. And im always 3 generations in the past. :mrgreen:
Post by SorenR » 2019-05-04 21:11
2019-05-04 20:40
2019-05-04 20:15
Todays flavor :mrgreen:
Disclaimer. Not all variables are declared in the sample code....
Function AutoBan is now boolean so that only a successfull ban is True in case of code executing in parallel.
Usage of "On Error" has been minimised to absolute minimum.
'***** SAMPLE START *****
Private Const PASSWORD = "very secret!"
'   Various settings
Private Const EVENTDIR = "C:\hMailServer\Events"
Private Const LOGDIR   = "C:\hMailServer\Logs"
Private Const TEMPDIR  = "C:\hMailServer\Temp"
'   Reject HELO
strRegEx = GetXMLNode(XMLDATA, "//Reject/HELO")
   If AutoBan(oClient.IPAddress, "//Reject/HELO/" & Match.Value, 12, "h") Then _
      EventLog.Write( LPad("Reject HELO", 15, " ") & vbTab & LPad(oClient.IPAddress, 16, " ") & vbTab & oClient.HELO )
   Exit Sub
'***** SAMPLE END *****
Function Wait(sec)
   Const Append = 8
   Const Unicode = -1
   Dim i
      For i = 0 To 30
         Err.Clear
         Set LockFile = .OpenTextFile(strPath, Append, True, Unicode)
         If (Not Err.Number = 70) Then Exit For
         Wait(1)
      Err.Clear
      Err.Clear
   On Error Goto 0
   With LockFile(TEMPDIR & "\autoban.lck")
      Dim oSecurityRange : Set oSecurityRange = oApp.Settings.SecurityRanges.ItemByName("(" & sReason & ") " & sIPAddress)
      If Err.Number = 9 Then
            .Priority = 20
            .Expires = True
            .Save
         AutoBan = True
      On Error Goto 0
      .Close
   Set oApp = Nothing
Function LPad(str, length, pad)
   LPad = Left(CStr(str) & String(length, pad), length)
Function RPad(str, length, pad)
   RPad = Right(String(length, pad) & CStr(str), length)
      .Pattern = strRegEx
      .Global = bGlobal
      .MultiLine = True
      .IgnoreCase = True
Function GetXMLNode(XMLFile, MyNode) : GetXMLNode = ""
   Dim Match, Matches, strTXT : strTXT = ""
   If oXML.Load(EVENTDIR & "\" & XMLFile) Then
         If (Trim(Match.Text) <> "") Then strTXT = strTXT & Trim(Match.Text) & "|"
         GetXMLNode = Left(strTXT,Len(strTXT)-1)
         EventLog.Write( "ERROR: Empty string from GetXMLNode(XMLDATA, " & MyNode & ")" )
         GetXMLNode = "VOID"
      Set Matches = Nothing
      EventLog.Write( "Your XML Document " & XMLFile & " failed to load due the following error." & vbCrLf & _
                      "Error #: " & oXML.ParseError.errorCode & ": " & oXML.ParseError.reason & _
                      "Line #: " & oXML.ParseError.line & vbCrLf & _
                      "Line Position: " & oXML.ParseError.linePos & vbCrLf & _
                      "Position In File: " & oXML.ParseError.filePos & vbCrLf & _
                      "Source Text: " & oXML.ParseError.srcText & vbCrLf & _
                      "Document URL: " & oXML.ParseError.url )
   Set oXML = Nothing
Post by palinka » 2019-05-04 21:13
2019-05-04 20:12
I just went to copy it in and saw that it was always there. in fact I compared the two and both functions were verbatim the same.
I did find one thing that I assumed was a typo. In the function in your example eventhandlers.vbs above, you have this (same as the one you just posted):
But everywhere else, its referenced as XMLDATA:
Sub OnHELO(oClient)
That gave me an error (forgot exactly what the error was) but it went away when I changed them all to XMLFile. I assumed that was a typo.
Post by palinka » 2019-05-04 21:31
2019-05-04 21:13
Sub OnHELO(oClient)
oops. I think I found the error. Somehow this got deleted.
I loaded in your new stuff, fixed the missing dim above and now I'm going to All American Burger with the wife and wee one. I'll check the logs when I get back. Hopefully this fixes the errors.
I have a ton of questions too, but I'll throw them at you after I stop getting errors.
Post by palinka » 2019-05-04 21:33
One more thing - I added this to the top of eventhandlers. Very handy when looking at the logs! :D
CODE 01 :: Snowshoe Spam
CODE 02 :: Deny servers with specific HELO/EHLO greetings
CODE 03 :: Invalid HELO/EHLO greeting
CODE 04 :: Reject specific X-Envelope-From
CODE 05 :: Reject specific From addresses
CODE 06 :: Reject specific Subject lines
CODE 07 :: Reject specific text found within message Body
CODE 08 ::
CODE 09 :: Reject specific <List-Unsubscribe> entries
CODE 10 :: Bots using residential ddns
CODE 11 ::
Post by palinka » 2019-05-05 03:24
Wow. Incredible decrease in spam. Mostly due to the spamhaus thing. Ever worry about false positives?
No errors in several hours so i think it's all going well.
One sneaky bastard snuck through.
SMTPD – 1717 – 176.58.160.41 ?
2019-05-04 20:29:44.158 RECEIVED: EHLO adsl-41.176.58.160.tellas.gr
Is there a regex for random order?
Also, is helo = ip only ok? I see you let them through. Ther only ones i see that are ip only helo are spam or password guessers or "half connections".
Post by SorenR » 2019-05-05 10:19
the helo check is RFC compliant and it's not "just" an IP, it has to be [ip] in square brackets. if you want to be completely anal then oclient.ipaddress must match ip address in oclient.helo 😎
Post by palinka » 2019-05-05 14:53
I'm using this (another of yours :mrgreen: ) to check for residential IPs/bots.
	'	Filter bots using residential ddns
   Dim a, b(3), i
   a = Split(oClient.IPAddress, ".")
   For i = 0 to 3
      b(i) = Right("00" & a(i),3)
   strRegEx = "(" & a(0) & "-" & a(1) & "-" & a(2) & "-" & a(3) & ")|" &_
              "(" & b(0) & "-" & b(1) & "-" & b(2) & "-" & b(3) & ")|" &_
              "(" & a(3) & "-" & a(2) & "-" & a(1) & "-" & a(0) & ")|" &_
              "(" & b(3) & "-" & b(2) & "-" & b(1) & "-" & b(0) & ")|" &_
		"(" & a(0) & "." & a(1) & "." & a(2) & "." & a(3) & ")|" &_
              "(" & b(0) & "." & b(1) & "." & b(2) & "." & b(3) & ")|" &_
              "(" & a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ")|" &_
              "(" & b(3) & "." & b(2) & "." & b(1) & "." & b(0) & ")"
      Result.Value = 2
      Result.Message = "530 CODE10 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means."
      Call AutoBan(oClient.IPAddress, "Residential IP - " & oClient.HELO, 7, "d")
It didn't work on the example I posted above because the IP address was randomized in the domain:
IP = 176.58.160.41
HELO = adsl-41.176.58.160.tellas.gr
This appears to me to be a residential or business hostname that a bot is using to present a bonafide looking HELO. I have a test script to randomize using OR but I can't make it work. I'm getting "type mismatch", error message is this:
Type Mismatch: '[string: "(176"]'
strRegEx =	"(" & a(0) OR a(1) OR a(2) OR a(3) & ") "-" " &_
			"(" & a(0) OR a(1) OR a(2) OR a(3) & ")"
What am I doing wrong?
Post by palinka » 2019-05-05 20:16
Got it. :D
strRegEx = "((" & a(0) & "|" & a(1) & "|" & a(2) & "|" & a(3) & ")-" &_
            "(" & a(0) & "|" & a(1) & "|" & a(2) & "|" & a(3) & ")-" &_
            "(" & a(0) & "|" & a(1) & "|" & a(2) & "|" & a(3) & "))|" &_
           "((" & a(0) & "|" & a(1) & "|" & a(2) & "|" & a(3) & ")." &_
            "(" & a(0) & "|" & a(1) & "|" & a(2) & "|" & a(3) & ")." &_
            "(" & a(0) & "|" & a(1) & "|" & a(2) & "|" & a(3) & "))"
Post by palinka » 2019-05-05 20:40
OK, now that everything is running smoothly, I have a couple of questions.
I don't understand this one.
OnAcceptMessage
         Result.Value = 2
         Exit Sub
Also, for this:
What kind of variable are you using there? An unsubscribe address? There was no entry for it in your sample xml file.
By the way, not a single spam made it through today where I was getting around 20/day before. SA does a good job processing them - users didn't receive spam, but my server did. Now, spam isn't even getting received. :mrgreen:
Post by SorenR » 2019-05-05 22:27
2019-05-05 20:40
OnAcceptMessage
         Result.Value = 2
         Exit Sub
Also, for this:
If you are not using a Backup-MX forget that section. I use a Backup-MX and when I ban servers they try via my Backup-MX service (which I don't control) and so I made a function to extract originating server and check if banned.
The "List-Unsubscribe" is one that is haunting me and have been doing for a long time. It's the only true identifier I can find in all these particular SPAM messages so that's it.
Use with caution, you might catch some HAM with it :mrgreen:
<List-Unsubscribe>(\&lt;http(s?):\/\/(.*)\/unsubscribe\.php\?M=(.*)&amp;C=(.*)&amp;L=(.*)&amp;N=(.*)\&gt;)</List-Unsubscribe>
It will match against oMessage.HeaderValue("List-Unsubscribe")
Post by palinka » 2019-05-05 23:41
2019-05-05 22:27
OK thanks. I do have a backup-mx service and in fact there is something strange going on with it that I don't recall seeing before.
"DEBUG"	11620	"2019-05-05 13:42:46.896"	"Creating session 1397"
"TCPIP"	11620	"2019-05-05 13:42:48.192"	"TCP - 184.105.182.145 connected to 192.168.1.2:25."
"DEBUG"	11620	"2019-05-05 13:42:48.192"	"Executing event OnClientConnect"
"DEBUG"	11620	"2019-05-05 13:42:48.224"	"Event completed"
"DEBUG"	11620	"2019-05-05 13:42:48.224"	"TCP connection started for session 1397"
"SMTPD"	11620	1397	"2019-05-05 13:42:48.224"	"184.105.182.145"	"SENT: 220 mydomain.tld"
"SMTPD"	8356	1397	"2019-05-05 13:42:48.302"	"184.105.182.145"	"RECEIVED: EHLO 145-he.filtered.junkemailfilter.com"
"DEBUG"	8356	"2019-05-05 13:42:48.302"	"Executing event OnHELO"
"DEBUG"	8356	"2019-05-05 13:42:48.317"	"Event completed"
"SMTPD"	8356	1397	"2019-05-05 13:42:48.333"	"184.105.182.145"	"SENT: 250-mydomain.tld[nl]250-SIZE 20480000[nl]250-STARTTLS[nl]250 HELP"
"SMTPD"	11620	1397	"2019-05-05 13:42:48.396"	"184.105.182.145"	"RECEIVED: STARTTLS"
"SMTPD"	11620	1397	"2019-05-05 13:42:48.396"	"184.105.182.145"	"SENT: 220 Ready to start TLS"
"DEBUG"	8356	"2019-05-05 13:42:48.396"	"Performing SSL/TLS handshake for session 1397. Verify certificate: False"
"TCPIP"	8356	"2019-05-05 13:42:48.583"	"TCPConnection - TLS/SSL handshake completed. Session Id: 1397, Remote IP: 184.105.182.145, Version: TLSv1.2, Cipher: ECDHE-RSA-AES256-GCM-SHA384, Bits: 256"
"SMTPD"	8356	1397	"2019-05-05 13:42:48.646"	"184.105.182.145"	"RECEIVED: EHLO 145-he.filtered.junkemailfilter.com"
"DEBUG"	8356	"2019-05-05 13:42:48.646"	"Executing event OnHELO"
"DEBUG"	8356	"2019-05-05 13:42:48.677"	"Event completed"
"SMTPD"	8356	1397	"2019-05-05 13:42:48.677"	"184.105.182.145"	"SENT: 250-mydomain.tld[nl]250-SIZE 20480000[nl]250 HELP"
"SMTPD"	8356	1397	"2019-05-05 13:42:48.755"	"184.105.182.145"	"RECEIVED: MAIL FROM:<fabianmdbnypbbeck@bmunboxing.icu>"
"TCPIP"	8356	"2019-05-05 13:42:48.786"	"DNS lookup: 145.182.105.184.zen.spamhaus.org, 0 addresses found: (none), Match: False"
"TCPIP"	8356	"2019-05-05 13:42:48.880"	"DNS lookup: 145.182.105.184.bl.spamcop.net, 0 addresses found: (none), Match: False"
"DEBUG"	8356	"2019-05-05 13:42:48.880"	"Spam test: SpamTestDNSBlackLists, Score: 0"
"DEBUG"	8356	"2019-05-05 13:42:48.958"	"Spam test: SpamTestHeloHost, Score: 0"
"DEBUG"	8356	"2019-05-05 13:42:49.161"	"Spam test: SpamTestMXRecords, Score: 0"
"DEBUG"	8356	"2019-05-05 13:42:49.599"	"Spam test: SpamTestSPF, Score: 0"
"DEBUG"	8356	"2019-05-05 13:42:49.599"	"Total spam score: 0"
"SMTPD"	8356	1397	"2019-05-05 13:42:49.614"	"184.105.182.145"	"SENT: 250 OK"
"SMTPD"	11620	1397	"2019-05-05 13:42:49.677"	"184.105.182.145"	"RECEIVED: RCPT TO:<barb@mydomain.tld>"
"SMTPD"	11620	1397	"2019-05-05 13:42:49.692"	"184.105.182.145"	"SENT: 250 OK"
"SMTPD"	7288	1397	"2019-05-05 13:42:49.755"	"184.105.182.145"	"RECEIVED: QUIT"
"DEBUG"	7288	"2019-05-05 13:42:49.755"	"Deleting message file."
"SMTPD"	7288	1397	"2019-05-05 13:42:49.755"	"184.105.182.145"	"SENT: 221 goodbye"
"DEBUG"	8356	"2019-05-05 13:42:49.755"	"Ending session 1397"
When I saw the first one, I was surprised nothing came through to my spam repository for SA-learn training. I looked around trying to find WTF happened and finally I saw that the connection quit. No big deal because I know these messages from today are all actual spam, but I hope it doesn't happen with any bona fide ham.
I'm pretty sure this has nothing to do whatsoever with the changes I made over the last few days or hmailserver at all, but what do you think?
Post by palinka » 2019-05-06 04:41
2019-05-04 21:11
Gonna need some help with this one.
"ERROR" 4544 "2019-05-05 22:28:49.718" "Script Error: Source: Microsoft VBScript runtime error - Error: 800A01C2 - Description: Wrong number of arguments or invalid property assignment: 'GetXMLNode' - Line: 583 Column: 14 - Code: (null)"
"ERROR" 2736 "2019-05-05 22:28:50.608" "Script Error: Source: Microsoft VBScript runtime error - Error: 800A01C2 - Description: Wrong number of arguments or invalid property assignment: 'GetXMLNode' - Line: 667 Column: 14 - Code: (null)"
Here in your example you used XMLFILE which I changed to XMLDATA.
Function GetXMLNode(XMLDATA, MyNode) : GetXMLNode = ""
   If oXML.Load(EVENTDIR & "\" & XMLDATA) Then
         GetXMLNode = "VOID"
      EventLog.Write( "Your XML Document " & XMLDATA & " failed to load due the following error." & vbCrLf & _
   Set oXML = Nothing
Line 583 is Dim...
Sub OnHELO(oClient)
   Dim oXML : Set oXML = GetXMLNode(XMLDATA)
Per your example, I changed all these xml to GetXMLNode
	   Exit Sub
Line 667 is the Dim...
Post by SorenR » 2019-05-06 11:59
2019-05-06 04:41
2019-05-04 21:11
Line 583 is Dim...
Sub OnHELO(oClient)
No longer needed. When you remove "Dim oXML : Set oXML = LoadXML(XMLDATA)" also remove "Set oXML = Nothing" or you will get another error.
Old code:
Sub OnSomeEvent(oClient)
      '   Reject HELO
         EventLog.Write( LPad("Reject HELO", 15, " ") & vbTab & oClient.IPAddress )
         Call AutoBan(oClient.IPAddress, "//Reject/HELO/" & Match.Value, 12, "h")
         Set oXML = Nothing
         Exit Sub
New code:
      '   Reject HELO
         Exit Sub
Also notice that with the new Bolean AutoBan code you can
Call AutoBan(oClient.IPAddress, "Scum of the earth "  & Match.Value, 12, "h")
or you can
If AutoBan(oClient.IPAddress, "Scum of the earth "  & Match.Value, 12, "h") Then
   EventLog.Write( "Successful ban, wohoo!" )
   EventLog.Write( "Ban exists, Another thread/session got there before me" )
The second instance happens if connecting server send a flood of connects. If an active connection exists, it cannot be terminated with autoban until service is returned to core code and issues a "Result.Value = 1" or higher.
Post by palinka » 2019-05-06 13:57
Awesome! Thanks, man!
One question - I successfully banned google during testing (using //Reject/Subject). :roll: I removed the autoban from IP Ranges, but now its in the ban db, I think. What will happen on next connect? Obviously, I don't want to block google no matter how evil they are... :evil: Too many friendly connections to blast away like this:
YOU'VE BEEN TERMINATED! :mrgreen:
Post by palinka » 2019-05-06 14:01
One more thing. To give back in the tiny way that I can, I have (more) perfected the search string for bots on residential FQDN.
	'	Filter bots using residential FQDN
   Dim a, b(3), i
   For i = 0 to 3
   strRegEx = "((" & a(0) & "|" & a(1) & "|" & a(2) & "|" & a(3) & "|" & b(0) & "|" & b(1) & "|" & b(2) & "|" & b(3) & ")(-|\.)" &_
               "(" & a(0) & "|" & a(1) & "|" & a(2) & "|" & a(3) & "|" & b(0) & "|" & b(1) & "|" & b(2) & "|" & b(3) & ")(-|\.)" &_
               "(" & a(0) & "|" & a(1) & "|" & a(2) & "|" & a(3) & "|" & b(0) & "|" & b(1) & "|" & b(2) & "|" & b(3) & "))"
      Result.Value = 2
      Call AutoBan(oClient.IPAddress, "BOT using Res FQDN - " & oClient.HELO, 7, "d")
As far as I'm concerned, HELO = IP is spam even if its presented in brackets per the "code".
Post by SorenR » 2019-05-06 16:55
2019-05-06 14:01
The HELO check for [IPv4], [IPv6] or FQDN is to satisfy RFC, not anti-SPAM. It will however filter out various bots using malformed FQDN or simple IP greetings.
Gordonh1970
Post by Gordonh1970 » 2019-05-11 21:21
Thank you for posting this, I'm very interested in trying it out
Unfortunately, with all the discussions that have gone on in the thread I can't work out what the latest EventHandler.vbs and Handler.vbs is (I'm really only interested in bloacking the failed login attempts at the mopment)
There's lots of other bits of code in the ongoing discussion but they're not labelled as to which file they refer to
If you can post the latest EventHandler.vbs and Handler.vbs and mention any dependancies (I'm assuming that MySQL ODBC is a dependancy) then it would be very much appreciated
Post by SorenR » 2019-05-12 10:58
Gordonh1970 wrote:
2019-05-11 21:21
Failed logins are handled by hMailServer directly, not by scripting.
https://www.hmailserver.com/documentati ... ce_autoban
Post by palinka » 2019-05-12 14:31
FYI - running Handler.vbs from task manager will "wake up" hmailserver service. I found that from running Jimi's backup script which shuts down hmailserver service during the backup. Something was turning on the service before the backup completed. I finally nailed it down to Handler.vbs running every minute from win task scheduler. All good now. I set it up to not run at the time the backup runs, then resume shortly after.
Post by SorenR » 2019-05-12 17:45
2019-05-12 14:31
I knew that... I have a "CheckState" job running every 5 minutes for that specific reason ... :mrgreen:
      EventLog.Write("CheckState: Server is currently doing backup...")
      EventLog.Write("CheckState: Server was stopped for no reason, starting...")
      Call oApp.Start
Post by palinka » 2019-05-12 17:50
2019-05-12 17:45
2019-05-12 14:31
      Call oApp.Start
I do it in powershell.
$ErrorActionPreference = 'silentlycontinue'
$command = "cmd /C cscript C:\scripts\hmailserver\Handlers.vbs"
$StartTime = (Get-Date 00:30)
$EndTime = (Get-Date 23:45)
$Now = Get-Date
if ($Now -gt $EndTime){exit}
elseif ($Now -lt $StartTime){exit}
else {
	invoke-expression $command
	Start-Sleep -seconds 60
For whatever reason, powershell comes a lot easier to me than vbs. I had a bit of trouble crossing midnight, but the above works.
Post by palinka » 2019-05-21 12:24
2019-05-06 11:59
or you can
I have a question. I have lots of autoban entries like this: (GEOBLOCK - IMAPS) 185.100.87.245. I assume this gets called from handlers.vbs because I am not calling autoban from OnClientConnect > geoip lookup. What does "geoblock" mean, exactly? Is it actually blocking by geoIP? If it is, how are the countries specified? I'm using an older version of your geoIP lookup (OnClientConnect) that I modified. I just want to make sure I'm not accidentally blocking the wrong countries. Thanks.
Post by palinka » 2019-05-21 12:46
By the way, here is my modified version of your old geoip lookup. I split it between port 25 and all others. I expect mail from lots of different places, but nobody should be connecting to imap or pop from anywhere but home. I would block imap and pop on the internet range completely except I have one single user that connects via imap and another one that uses a gmail account to pop download mail. Everyone else either uses webmail or horde activesync, which both come across on the localhost.
I just now added the autoban. I'll keep an eye on it for the gmail pop connections. I don't think they connect from anywhere but silly-con valley.
OnClientConnect:
	'	GEOIP Lookup
   Dim ReturnCode, Json, oGeoip, oXML, strPort, strBase
   strPort = Trim(Mid("SMTP POP  IMAP SMTPSSUBM IMAPSPOPS ", InStr("25   110  143  465  587  993  995  ", oClient.Port), 5))
   Set Json = New VbsJson
   Set oXML = CreateObject ("Msxml2.XMLHTTP.3.0")
   oXML.Open "GET", "http://ip-api.com/json/" & oClient.IPAddress, False
   oXML.Send
   Set oGeoip = Json.Decode(oXML.responseText)
   ReturnCode = oXML.Status
   On Error Goto 0
   If (ReturnCode <> 200 ) Then
      EventLog.Write("<OnClientConnect.error> ip-api.com lookup failed, error code: " & ReturnCode & " on IP address " & oClient.IPAddress)
      Exit Sub
   ' ALLOWED COUNTRIES - Port 25 only... Check Alpha-2 Code here -> https://en.wikipedia.org/wiki/ISO_3166-1
	   strBase = "^(US|CA|AT|BE|DE|DK|ES|FR|GB|GL|GR|HU|IE|IS|IT|LI|NL|NO|PL|PT|RO|SE|SI|SK|AU|NZ)$"
	   If Lookup(strBase, oGeoip("countryCode")) Then
		  EventLog.Write(strPort & " Connection accepted" & Chr(34) & vbTab & oClient.IPAddress & vbTab & Chr(34) & oGeoip("countryCode") & Chr(34) & vbTab & Chr(34) & oGeoip("country"))
	   Exit Sub
   ' Disconnect all others connecting to port 25.
	   Result.Value = 1
       Call AutoBan(oClient.IPAddress, "GeoIP - " & oClient.IpAddress, 7, "d")
	   EventLog.Write(strPort & " Connection REJECTED" & Chr(34) & vbTab & oClient.IPAddress & vbTab & Chr(34) & oGeoip("countryCode") & Chr(34) & vbTab & Chr(34) & oGeoip("country"))
	   Exit Sub
   ' ALLOWED COUNTRIES - All ports except 25... Check Alpha-2 Code here -> https://en.wikipedia.org/wiki/ISO_3166-1
	   strBase = "^(US)$"
		  Exit Sub
   ' Disconnect all others connecting to any port except 25.
	   Result.Value = 1
	   Exit Sub
Re: Hardening hMailServer - The ongoing saga!
Post by SorenR » 2019-05-21 14:36
	   Result.Value = 1
	   Exit Sub
Insert information into the DB for handler.vbs to deal with... oClient.Port tell handler.vbs this is a GEOip block...
Why ?? This should be done by handler.vbs UNLESS you disabled the code in handler.vbs. (*NOTE)
(*NOTE) Actually I have changed my code so Call idsAddIP is ONLY used for IDS and NOT GEOip blocking thus the line "Call idsAddIP(oClient.IPAddress, oClient.Port)" should go and the line "Call AutoBan(oClient.IPAddress, "GeoIP - " & oClient.IpAddress, 7, "d")" should stay.
Perhaps I should post the latest version but I'm a bit crippled atm. The Power circuit on my "work pc" mainboard died (Dell D610) and the only other machine I have spare is a Acer Aspire 5552 with an AMD Athlon II and 16:9. Prognosis is good, I got my old 32 bit XP SP3 back up running with a million new drivers... The challenge is doing the swap without doing a clean install - I have so much crap on this system that it would take a month if I can find all the software in my archive or online.
Fortunately I did a mirror backup of the harddrive only a few days ago... Intel Pentium M -> AMD Dual core. IDE -> SATA and XP don't like SATA. It runs, I got internet, office works (sort of - keeps asking for activation), Internet Explorer don't so something is F'd...
" I will initiate self-destruct. " — IG-11.
Post by palinka » 2019-05-21 18:03
2019-05-21 14:36
Did you drag that thing out of a time capsule or something? Those antiques might be worth something today if you throw a couple of kroner inside the case. LOL
I think my ProTools mixing station in 2000 was on an Athlon based box running windows 98. It must have been the original Athlon in that year. It was rockin' back then. Blew the macs away on every measurement. Of course, back then macs were running motorola chips which were not getting any attention after suddenly motorola discovered it could make 100 times more on cell phones than cpu's for a niche market.
Post by SorenR » 2019-05-21 21:25
2019-05-21 18:03
2019-05-21 14:36
It has to match the other old stuff I have... :mrgreen:
Ferguson (lawn mover) - 1952
House & "toolshed" - 1967
Audi Quattro (urquattro) - 1982
Golf Cabriolet (Etienne Aigner edition) 1990
Post by palinka » 2019-05-21 22:17
Nice mower. Do you bale it? Or stack it like the old days? :mrgreen:
Post by SorenR » 2019-05-21 23:32
2019-05-21 22:17
I'm hosting horses for a friend from time to time so 6 of the 12 acres I don't have to touch, the rest is kept short.
Working the wood chipper clearing up years of dead wood. I've owned the place since 2005 and last year we moved up here for good. We have all sorts of birds, ducks and cranes in the pond. Been feeding a couple of Pheasants all winter and a red tailed woodpecker, deer, a red fox, several birds of pray and a Sea Eagle family <-- That is a bloody big bird!
Dog (German Pointer bitch) saved one of the Pheasants from the Fox the other day. :mrgreen:
So that is why, sometimes, I don't respond promptly on forum... Either outside working or just staring out the window looking at nature 8)
Post by palinka » 2019-05-22 00:23
Beautiful. Looks like an awesome place to live.
Post by palinka » 2019-05-22 01:35
By the way, after implementing your event handlers, i went from 20 to 30 spam per day to 1 to 3. Very nice! When i get some time, I'll try to figure out how to knock that down even further. There's a pattern I've noticed for spam addresses that make it through is "Somefirstname <DifferentfirstnameLastname@bogusdomain.tld>". The capital letters for first and last name with no digits, dashes or dots PLUS the different name than the email are a dead giveaway. A pattern easily recognized by human eyes. Now i have to figure out how to regex that. :mrgreen:
Post by SorenR » 2019-05-22 08:19
2019-05-22 01:35
Look at all the headers. I look for oMessage.FromAddress since this is the actual email sender and sometimes also oMessage.From for known spammers but mostly to whitelist contact(s).
It will be very difficult to target "FirstnameLastname" as you are bound to catch some innocent victims.
Check headers, use EventLog.Write to write out specific headers so you can look for commonalities that will identify SPAM... Sometimes it takes 1 week but most often longer to figure out the similarities. It took me almost 3 weeks until I figured out that a specific "List-Unsubscribe" template could catch spammers. It all depend on the software they use.
Post by palinka » 2019-05-30 02:18
2019-05-22 08:19
I've been monitoring this (receiving notifications on a hit, but taking no action) and I'm getting nothing but VictoriasSecret and a couple other hams. No worky. :cry:
However, I further tweaked the IP as HELO.
   Dim a, i
   For i = 0 to 3
   strRegEx = "((" & a(0) & "|" & a(1) & "|" & a(2) & "|" & a(3) & ")(.+)" &_
               "(" & a(0) & "|" & a(1) & "|" & a(2) & "|" & a(3) & ")(.+)" &_
      Result.Value = 2
      EventLog.Write( LPad("Bot on Res FQDN", 15, " ") & vbTab & oClient.IPAddress )
This picks up the following on a test run:
IPAddress = "193.126.23.235"
HELO = "193-126-23-235.static.optimus.net.pt"
IPAddress = "85.57.145.95"
HELO = "95.pool85-57-145.dynamic.orange.es"
IPAddress = "83.59.97.107"
HELO = "107.red-83-59-97.dynamicip.rima-tde.net"
Even when the IP numbers are out of order or have other crud mixed between they get picked up. Does NOT hit if any of the IP numbers are different than the ones in HELO. Positive matches must contain all of the IP numbers.
Post by RvdH » 2019-06-01 00:31
That also matches:
HELO = "[193.126.23.235]"
Which is allowed, see RFC2821 4.1.3
But i think this will do to filter out ip4 and ip6 adresses between brackets
strRegEx="^(?!(?:\[)(?:(?:ipv6.+)|(?:[0-9]{1,3}[.-]){3}[0-9]{1,3})(?:\])$)" &_
Post by palinka » 2019-06-01 22:11
2019-06-01 00:31
That also matches:
Good stuff. Thanks!
Post by RvdH » 2019-06-02 01:59
And it can shortened...ps i have seen cases ip adresses are zero prefixed (see example 107.red-083-059-097.dynamicip.rima-tde.net), my final regexp would look something like:
	strRegEx = 	"^(?!(?:\[)(?:(?:ipv6.+)|(?:[0-9]{1,3}[.-]){3}[0-9]{1,3})(?:\]))" &_
				"(.*(((?:[0]{0,2})" & a(0) & "|(?:[0]{0,2})" & a(1) & "|(?:[0]{0,2})" & a(2) & "|(?:[0]{0,2})" & a(3) & ")(?:.+)){3}" &_
				"((?:[0]{0,2})" & a(0) & "|(?:[0]{0,2})" & a(1) & "|(?:[0]{0,2})" & a(2) & "|(?:[0]{0,2})" & a(3) & ").+)$"
Dim arr(9,1) ' Which has 9 rows and 2 columns
arr(0,0) = "193.126.23.235"
arr(0,1) = "193-126-23-235.static.optimus.net.pt"
arr(1,0) = "85.57.145.95"
arr(1,1) = "95.pool85-57-145.dynamic.orange.es"
arr(2,0) = "83.59.97.107"
arr(2,1) = "107.red-83-59-97.dynamicip.rima-tde.net"
arr(3,0) = "31.168.210.62"
arr(3,1) = "bzq-210-168-31-62.red.bezeqint.net"
arr(9,0) = "193.126.23.235"
arr(9,1) = "193.126.23.235"
arr(4,0) = "85.57.145.95"
arr(4,1) = "pool95.85-57-145.dynamic.orange.es"
arr(5,0) = "83.59.97.107"
arr(5,1) = "107.red-083-059-097.dynamicip.rima-tde.net"
arr(6,0) = "198.2.139.211"
arr(6,1) = "mail211.atl221.rsgsv.net"
arr(7,0) = "192.168.0.101"
arr(7,1) = "[IPv6:::ffff:192.168.0.101]"
arr(8,0) = "192.168.0.101"
arr(8,1) = "IPv6:::ffff:192.168.0.101"
dim a, strRegEx
'Fetching values from  2 Dimenional array
For i=0 to Ubound(arr,1) '  Ubound of first dimension
	a = Split(arr(i,0), ".")
	If Lookup(strRegEx, arr(i,1)) Then
		MsgBox "IPAddress = "  & arr(i,0) & VbCrLF & "HELO = " & arr(i,1)
	end If
		.Global = False
		.Pattern = strRegEx
		.IgnoreCase = True
		Lookup = .Test(strMatch)
Post by palinka » 2019-06-02 03:52
This is pretty slick. I'm going to give it a shot. Thanks!
Post by palinka » 2019-10-28 17:44
Fun with PTR.
I've been using a variation of the above dynamic looking HELO filter for a while. Today I came up with an idea and I tested it out against banned IPs in my Firewall Ban project.
Function PTRLookup(strIP)
	Dim strLookup, strPTR
		strLookup = .PTR(strIP)
	If strLookup = Empty Then strPTR = "No.PTR.Record" Else strPTR = strLookup End If
	PTRLookup = strPTR
Sub OnHELO(oClient)
	'	Grab PTR-Record
	Dim PTR_Record
	PTR_Record = PTRLookup(oClient.IPAddress)
	'	Reject on No-PTR
	If (oClient.Port = 25) Then
		If PTR_Record = "No.PTR.Record" Then
			Result.Value = 2
			Result.Message = ". 03 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means."
			Call FWBan(oClient.IPAddress, "No-PTR", oClient.HELO)
			Call AutoBan(oClient.IPAddress, "No-PTR - " & oClient.IpAddress, 1, "h")
			Call AccRejDB(strPort, oClient.Port, "OnHELO", "REJECTED", "No-PTR", oClient.IPAddress, oClient.HELO)
			Exit Sub
	'   Filter bots using residential FQDN as HELO
	Dim a, i
	For i = 0 to 3
	'   Exclude certain false positives
	strRegEx = "sendgrid|facebook.com"
	'   Search for residential looking HELO
	strRegEx = 	"(.*(((?:[0]{0,2})" & a(0) & "|(?:[0]{0,2})" & a(1) & "|(?:[0]{0,2})" & a(2) & "|(?:[0]{0,2})" & a(3) & ")(?:.+)){3}" &_
			Result.Value = 2
			Result.Message = ". 05 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means."
			Exit Sub
	'	Filter dynamic-looking PTR-Record
	If PTR_Record <> "" Then
		If Lookup(strRegEx, PTR_Record) Then Exit Sub
				Result.Value = 2
				Result.Message = ". 18 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means."
I just ran a PTR lookup for every record in my Firewall Ban project from the United States (has passed GeoIP filter). I have 1,085 bans from US on Firewall Ban for a variety of reasons, but mostly for hitting Spamhaus Zen. Of those that have a PTR record, 412 hit the "Dynamic-Looking PTR" filter. Of those, I excluded HELO entries that also hit the same filter (e.g. HELO: 24-181-205-130.static.hckr.nc.charter.com, PTR: 24-181-205-130.static.hckr.nc.charter.com) and came up with 235 that hit the filter, which are the ones that would not have hit on filter "bots using residential FQDN as HELO". So right there is an improvement. 269 had no PTR record.
So, 63% of known spammers got picked up by these rules. Not a bad tool to have.
By the way, what sparked my interest in this was occasionally getting network errors in geoip lookups. So I decided to put as much filtering as possible in a "local" sense. The PTR lookup is obviously not coming from a local database, but dns is crazy efficient and I only look it up once for the entire transaction.
Post by palinka » 2019-10-29 21:33
I ran a test on my entire firewall ban database and came up with this.
           11,349 IPs banned
 42.74%  -  4,851 No PTR
 29.09%  -  3,301 Dynamic looking PTR
  0.35%  -     40 Dynamic looking HELO (after testing PTR)
 27.82%  -  3,157 No matches
100.00%    11,349 IPs banned
            8,968 banned for GeoIP
            1,967 banned for Spamhaus
              414 banned for other reasons
           11,349 IPs banned
72% of known spammers got hit for either NO PTR or dynamic looking PTR. I'm rejecting both catagories now.
nitro
Post by nitro » 2019-10-31 10:28
2019-10-29 21:33
           11,349 IPs banned
           11,349 IPs banned
Thank you very much Palinka, I have followed your advice adapted your code and in a few hours I have rejected / banned more than 200 servers.
You have to be careful with the lords of Microsoft.
It can be a false positive in, FQDN as HELO.
AM5EUR02FT035.mail.protection.outlook.com
EUR04-DB3-obe.outbound.protection.outlook.com
EUR03-VE1-obe.outbound.protection.outlook.com
Post by palinka » 2019-10-31 10:58
nitro wrote:
2019-10-31 10:28
I discovered that yesterday too. I added outbound.protection.outlook.com$ to the list of "known false positives" so they skip the test.
ashtec014
Post by ashtec014 » 2019-11-11 17:43
2019-10-28 17:44
Fun with PTR.
	PTRLookup = strPTR
Sub OnHELO(oClient)
	'	Grab PTR-Record
	Dim PTR_Record
	'	Reject on No-PTR
			Result.Value = 2
			Exit Sub
	Dim a, i
	For i = 0 to 3
			Result.Value = 2
			Exit Sub
				Result.Value = 2
Hi Palinka,
I used your code above but got an error:
"ERROR"	11944	"2019-11-11 18:42:34.161"	"Script Error: Source: Microsoft VBScript runtime error - Error: 800A000D - Description: Type mismatch: 'Disconnect' - Line: 262 Column: 3 - Code: (null)"
Post by palinka » 2019-11-11 18:14
You probably don't have the disconnect function.
Function Disconnect(sIPAddress)
		.Run """C:\Program Files (x86)\hMailServer\Events\Disconnect.exe"" " & sIPAddress & "", 0, True
		REM EventLog.Write("Disconnect.exe " & sIPAddress & "")
You also need RvdH's disconnect.exe. Download it from here: https://d-fault.nl/files/Disconnect.zip and unzip it into your hmailserver\Events folder. Change the path in the function if it doesn't match your Events folder location.
Post by palinka » 2019-11-11 18:19
Also, I just looked at my script and see that I did not strip out some of my custom stuff.
This:
			Result.Value = 2
			Exit Sub
Really should be this with my crap stripped out:
			Result.Value = 2
			Exit Sub
Otherwise you'll get the same errors for calling FWBan and AccRejDB. If you copied Soren's stuff, you probably already have AutoBan. If not, you can find it above in this thread.
ashtec014
Post by ashtec014 » 2019-11-11 18:53
2019-11-11 18:19
This:
			Result.Value = 2
			Exit Sub
			Result.Value = 2
			Exit Sub
Hi Palinka,
It's working, Thank you so much. Now, I got this logs from the botnet every time they're trying to connect. I appreciate all your help and for sharing this script.
"SMTPD"	11896	1393	"2019-11-11 19:49:48.137"	"200.0.0.103"	"SENT: 220 mydomain.com ESMTP"
"SMTPD"	11112	1393	"2019-11-11 19:49:48.138"	"200.0.0.103"	"RECEIVED: EHLO Ammar"
"DEBUG"	11112	"2019-11-11 19:49:48.139"	"Executing event OnHELO"
"DEBUG"	11112	"2019-11-11 19:49:48.165"	"Event completed"
"SMTPD"	11112	1393	"2019-11-11 19:49:48.165"	"200.0.0.103"	"SENT: 554 . 03 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means."
"DEBUG"	11896	"2019-11-11 19:49:48.167"	"The read operation failed. Bytes transferred: 0 Remote IP: 200.0.0.103, Session: 1393, Code: 2, Message: End of file"
"DEBUG"	11896	"2019-11-11 19:49:48.167"	"Ending session 1393"
"DEBUG"	11896	"2019-11-11 19:49:48.172"	"Creating session 1397"
"TCPIP"	11896	"2019-11-11 19:49:48.172"	"TCP - 200.0.0.103 connected to 200.0.0.8:25."
"DEBUG"	11896	"2019-11-11 19:49:48.173"	"Executing event OnClientConnect"
"DEBUG"	4292	"2019-11-11 19:49:54.381"	"The read operation failed. Bytes transferred: 0 Remote IP: 200.0.0.103, Session: 1392, Code: 335544539, Message: short read"
"DEBUG"	4292	"2019-11-11 19:49:54.382"	"Ending session 1392"
"DEBUG"	11896	"2019-11-11 19:50:08.135"	"Event completed"
"DEBUG"	11896	"2019-11-11 19:50:08.135"	"TCP connection started for session 1396"
"SMTPD"	11896	1396	"2019-11-11 19:50:08.136"	"200.0.0.103"	"SENT: 220 mydomain.com ESMTP"
"SMTPD"	4292	1396	"2019-11-11 19:50:08.137"	"200.0.0.103"	"RECEIVED: EHLO Ammar"
"DEBUG"	4292	"2019-11-11 19:50:08.138"	"Executing event OnHELO"
"DEBUG"	4292	"2019-11-11 19:50:08.167"	"Event completed"
"SMTPD"	4292	1396	"2019-11-11 19:50:08.168"	"200.0.0.103"	"SENT: 554 . 03 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means."
"DEBUG"	11896	"2019-11-11 19:50:08.169"	"The read operation failed. Bytes transferred: 0 Remote IP: 200.0.0.103, Session: 1396, Code: 2, Message: End of file"
"DEBUG"	11896	"2019-11-11 19:50:08.170"	"Ending session 1396"
"DEBUG"	11896	"2019-11-11 19:50:08.173"	"Creating session 1398"
"TCPIP"	11896	"2019-11-11 19:50:08.173"	"TCP - 200.0.0.103 connected to 200.0.0.8:25."
"DEBUG"	11896	"2019-11-11 19:50:08.174"	"Executing event OnClientConnect"
"DEBUG"	4292	"2019-11-11 19:50:14.632"	"Ending session 1394"
"DEBUG"	6908	"2019-11-11 19:50:23.112"	"Creating session 1399"
"TCPIP"	6908	"2019-11-11 19:50:23.112"	"TCP - 200.0.0.103 connected to 200.0.0.8:995."
"DEBUG"	6908	"2019-11-11 19:50:23.113"	"Executing event OnClientConnect"
"DEBUG"	6908	"2019-11-11 19:50:23.114"	"Event completed"
"DEBUG"	6908	"2019-11-11 19:50:23.114"	"TCP connection started for session 1390"
"DEBUG"	6908	"2019-11-11 19:50:23.114"	"Performing SSL/TLS handshake for session 1390. Verify certificate: False"
"TCPIP"	4292	"2019-11-11 19:50:23.144"	"TCPConnection - TLS/SSL handshake completed. Session Id: 1390, Remote IP: 200.0.0.103, Version: TLSv1.2, Cipher: ECDHE-RSA-AES256-GCM-SHA384, Bits: 256"
"DEBUG"	11112	"2019-11-11 19:50:23.195"	"Executing event OnClientLogon"
"DEBUG"	11112	"2019-11-11 19:50:23.196"	"Event completed"
"DEBUG"	11112	"2019-11-11 19:50:23.254"	"Ending session 1390"
"DEBUG"	11896	"2019-11-11 19:50:28.144"	"Event completed"
"DEBUG"	11896	"2019-11-11 19:50:28.145"	"TCP connection started for session 1397"
"SMTPD"	11896	1397	"2019-11-11 19:50:28.145"	"200.0.0.103"	"SENT: 220 mydomain.com ESMTP"
"SMTPD"	11112	1397	"2019-11-11 19:50:28.148"	"200.0.0.103"	"RECEIVED: EHLO Ammar"
"DEBUG"	11112	"2019-11-11 19:50:28.148"	"Executing event OnHELO"
"DEBUG"	11112	"2019-11-11 19:50:28.197"	"Event completed"
"SMTPD"	11112	1397	"2019-11-11 19:50:28.198"	"200.0.0.103"	"SENT: 554 . 03 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means."
"DEBUG"	11112	"2019-11-11 19:50:28.200"	"The read operation failed. Bytes transferred: 0 Remote IP: 200.0.0.103, Session: 1397, Code: 2, Message: End of file"
"DEBUG"	11112	"2019-11-11 19:50:28.201"	"Ending session 1397"
"DEBUG"	11896	"2019-11-11 19:50:28.210"	"Creating session 1400"
"TCPIP"	11896	"2019-11-11 19:50:28.211"	"TCP - 200.0.0.103 connected to 200.0.0.8:25."
Post by palinka » 2019-11-11 19:50
Only check PTR on port 25. The logic behind that is only "real" mailservers should be connecting on port 25 and all of them should have a valid PTR.
If you check the PTR on submission ports or IMAP/POP3 ports, you'll be checking all kinds of legitimate mail clients and nearly none will pass the no/dyn PTR test. Nearly all legitimate users/clients will have dynamic IP/PTR or no PTR because they're not servers and can and should be allowed to connect from anywhere.
Your best bet is to let autoban do its job. Checking PTR is for rejecting incoming mail only.
ashtec014
Post by ashtec014 » 2019-11-16 07:54
2019-11-11 19:50
Thank you, I appreciate this.
I have one more question, how do I know if botnet has been banned? Is there a way I can check this?
Post by palinka » 2019-11-16 13:27
ashtec014 wrote:
2019-11-16 07:54
That depends on what you mean by ban. If you autoban rejections, then you can look in your ip ranges. If you firewall ban using my firewall ban project, there's a whole php web interface to keep track of them.
Autoban entries expire according to whatever time period that you choose. Firewall banning is permanent unless you decide to release the ip for some reason, including auto expiration on a time frame you choose.
