Delete mailbox for non existant AD user
tdemeyer
Post by tdemeyer » 2018-03-05 13:37
Hi script guru's out there...
I've been using a PS script to automatically create mailboxes for members of a given AD group (see another post of me). This works fine, but
I'm in need of a utility that does just the opposite: run through all mailboxes and if the corresponding user is no longer found to be member of the AD group, then delete the mailbox.
Any suggestion is welcome...
Tim
Re: Delete mailbox for non existant AD user
Post by jimimaseye » 2018-03-05 14:47
Should be easy enough for you. The documentation https://www.hmailserver.com/documentati ... e=overview and examples https://www.hmailserver.com/documentati ... m_examples will show you how to cycle through the domain accounts and obtain the email address from each account. The pass that variable in to your script that then looks it up in AD.
tdemeyer
Post by tdemeyer » 2018-03-05 17:33
After a few hours of trial and error, I found a working solution.
If anyone is interested...
Import-Module ActiveDirectory
$group = "ADGroupname"
$members = Get-ADGroupMember -Identity $group -Recursive | Select -ExpandProperty SamAccountName
    $hm = New-Object -ComObject hMailServer.Application
    $hm.Authenticate("admin", "adminpassword") | out-null
    $hmdom = $hm.Domains.ItemByName("staff.acme.com")
    $hmdomaccts = $hmdom.Accounts.Count()
    for ($i=$hmdomaccts-1;$i -ge 0;$i=$i-1) {
    $hmdomacct = $hmdom.Accounts.Item($i)
    $user = $hmdomacct.ADUsername
    If ( -not ($members -contains $user)) {
      $mailaddr = $hmdomacct.Address
      $acctID = $hmdom.Accounts.ItemByAddress($mailaddr)
      $hmdom.Accounts.DeleteByDBID($acctID.ID)
Maybe there's room for some cleaning up or tweaking, but at least this works..
Post by jimimaseye » 2018-03-05 19:26
That looks like exactly as I was thinking. Well done, thanks for sharing.
