Add timeout to script function?
insomniac2k2
Post by insomniac2k2 » 2018-02-21 19:17
I've ran into an issue several times where i will have a bunch of open sessions which are waiting for various lookup sites to reply. These open sessions eventually cause a thread lock on the hmail server. In order to prevent this, i've come to the conclusion that I need to add some sort of timeout in the lookup process. Basically, if lookup doesn't reply in 5 seconds, move on.
Example script function used by many here:
Sub OnClientConnect(oClient)
        If SpamRatsAuthHacker(oClient.IPAddress) Then
		Set oShell = CreateObject("WScript.Shell")
		'oShell.Run """C:\Program Files (x86)\hMailServer\Bin\ProxyAuth.exe"" -secret Mangos -ban " & oClient.IPAddress & " -bandays 180"
		 oShell.Run """C:\Program Files (x86)\hMailServer\Bin\ProxyAuth.exe"" -secret Mangos -ban " & oClient.IPAddress & " -bandays 180", 0, True
		Result.Value = 1
		EventLog.Write("Message from: " & oClient.IPAddress & " Blocked as authentication hacker - SpamRatsAuthHacker")
		Exit Sub
calls:
Function SpamRatsAuthHacker(strIP)
	SpamRatsAuthHacker = false
	Dim a : a = Split(strIP, ".")
	On Error Resume Next
		strIP = .DNSLookup(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".auth.spamrats.com")
	On Error Goto 0
	Dim strRegEx : strRegEx = "^(127\.0\.0\.43)$"
	SpamRatsAuthHacker = Lookup(strRegEx, strIP)
Ideally i would think the best place for timeout to be added to the function itself. Any thoughts on how to do that?
Apologies to moderators. I just realized that I posted this in the wrong place :/
Re: Add timeout to script function?
Post by SorenR » 2018-02-21 20:34
I know you can't use it in HM script but here goes ...
WScript.Echo WScript.Timeout
WScript.Timeout = 15
WScript.Echo "Start..."
While True
    WScript.Sleep 5000
    WScript.Echo "Tick..."
Wend
WScript.Echo "Stop..."
He he.....
Hint: perhaps look into calling the exe via PowerShell, IIRC you can set a timeout.
PS. Also came across this...
Exit code is WScript.Quit n where N is a 32 bit integer. It becomes the return code of the shell.
Post by RvdH » 2018-02-22 13:33
The DNSLibrary.DNSResolver component has a lookup timeout build-in and returns empty string if a timeout occurred.... so my guess the timeout occurs elsewhere, not in the lookup
insomniac2k2
Post by insomniac2k2 » 2018-02-22 16:57
Interesting. What is the default timeout? Because presently, I have a pretty busy server. It's not unusual to have most all threads open at the same time. Is it adjustable by ini?
Post by RvdH » 2018-02-22 17:46
I believe the Resolver in the component uses a timeout of 1000 milliseconds (3 retries)
This is not adjustable
insomniac2k2
Post by insomniac2k2 » 2018-02-22 19:20
Thanks. I'll poke around elsewhere then. 1000ms is definitely fine.
RvdH wrote:I believe the Resolver in the component uses a timeout of 1000 milliseconds (3 retries)
