Script to check attachments on VirusTotal using VT API
jamaisx
Post by jamaisx » 2017-07-20 10:55
Actually only do the search for existing scans, so it doesn't submit the file to VT site...
' EventHandler script used to check mail attachments on VirusTotal fired from hMailServer
' The script do the following things:
'   cycle the message attachments
'   save them in a temp folder
'   compute a MD5 checksum fo the attachment and delete the temporary file
'   query VirusTotal API to check if the MD5 is present
'   parse the json response and
'   if empty response write to eventlog
'   if valid response and response_code is "0", the file is not present in VirusTotal, only write the event log
'     if positives <>"0" the file is known to VirusTotal as dangerous, so the attachment is removed and the
'        mail subject tagged with the custom prefix
' Version 1.0 2017/07/20
' Go to OnAcceptMessage sub and define the following constants
'   Const tempPath = "e:\hMailServer\events\temp\"    ' existing path where the attachments will be temporarly stored
'   Const apikey ="you virustotal api key, got after registration"
'   Const prefix = "[VIRUSTOTAL-REMOVED-ATTACHMENT] "   ' a prefix injected before original mail subject if dangerous attachment found and removed
' Functions to compute MD5
' source https://stackoverflow.com/questions/10198690/how-to-generate-md5-using-vbscript-in-classic-asp thanks to "SgtWilko"
function md5hashBytes(aBytes)
    Dim MD5
    set MD5 = CreateObject("System.Security.Cryptography.MD5CryptoServiceProvider")
    MD5.Initialize()
    'Note you MUST use computehash_2 to get the correct version of this method, and the bytes MUST be double wrapped in brackets to ensure they get passed in correctly.
    md5hashBytes = MD5.ComputeHash_2( (aBytes) )
end function
function sha1hashBytes(aBytes)
    Dim sha1
    set sha1 = CreateObject("System.Security.Cryptography.SHA1Managed")
    sha1.Initialize()
    sha1hashBytes = sha1.ComputeHash_2( (aBytes) )
end function
function sha256hashBytes(aBytes)
    Dim sha256
    set sha256 = CreateObject("System.Security.Cryptography.SHA256Managed")
    sha256.Initialize()
    sha256hashBytes = sha256.ComputeHash_2( (aBytes) )
end function
function sha256HMACBytes(aBytes, aKey)
    Dim sha256
    set sha256 = CreateObject("System.Security.Cryptography.HMACSHA256")
    sha256.Initialize()
    sha256.key=aKey
    sha256HMACBytes = sha256.ComputeHash_2( (aBytes) )
end function
function stringToUTFBytes(aString)
    Dim UTF8
    Set UTF8 = CreateObject("System.Text.UTF8Encoding")
    stringToUTFBytes = UTF8.GetBytes_4(aString)
end function
function bytesToHex(aBytes)
    dim hexStr, x
    for x=1 to lenb(aBytes)
        hexStr= hex(ascb(midb( (aBytes),x,1)))
        if len(hexStr)=1 then hexStr="0" & hexStr
        bytesToHex=bytesToHex & hexStr
    next
end function
Function BytesToBase64(varBytes)
    With CreateObject("MSXML2.DomDocument").CreateElement("b64")
        .dataType = "bin.base64"
        .nodeTypedValue = varBytes
        BytesToBase64 = .Text
'Special version that produces the URLEncoded variant of Base64 used in JWTs.
Function BytesToBase64UrlEncode(varBytes)
        BytesToBase64UrlEncode = replace(replace(replace(replace(replace(.Text,chr(13),""),chr(10),""),"+", "-"),"/", "_"),"=", "")
Function GetBytes(sPath)
    With CreateObject("Adodb.Stream")
        .Type = 1 ' adTypeBinary
        .Open
        .LoadFromFile sPath
        .Position = 0
        GetBytes = .Read
        .Close
' Class used to parse Json response
' source http://demon.tw/my-work/vbs-json.html
Class VbsJson
   'Author: Demon
'Date: 2012/5/3
'Website: http://demon.tw
Private Whitespace, NumberRegex, StringChunk
Private b, f, r, n, t
Private Sub Class_Initialize
    Whitespace = " " & vbTab & vbCr & vbLf
    b = ChrW(8)
    f = vbFormFeed
    r = vbCr
    n = vbLf
    t = vbTab
    Set NumberRegex = New RegExp
    NumberRegex.Pattern = "(-?(?:0|[1-9]\d*))(\.\d+)?([eE][-+]?\d+)?"
    NumberRegex.Global = False
    NumberRegex.MultiLine = True
    NumberRegex.IgnoreCase = True
    Set StringChunk = New RegExp
    StringChunk.Pattern = "([\s\S]*?)([""\\\x00-\x1f])"
    StringChunk.Global = False
    StringChunk.MultiLine = True
    StringChunk.IgnoreCase = True
'Return a JSON string representation of a VBScript data structure
'Supports the following objects and types
'| VBScript          | JSON          |
'| Dictionary        | object        |
'| Array             | array         |
'| String            | string        |
'| Number            | number        |
'| True              | true          |
'| False             | false         |
'| Null              | null          |
Public Function Encode(ByRef obj)
    Dim buf, i, c, g
    Set buf = CreateObject("Scripting.Dictionary")
    Select Case VarType(obj)
        Case vbNull
            buf.Add buf.Count, "null"
        Case vbBoolean
            If obj Then
                buf.Add buf.Count, "true"
                buf.Add buf.Count, "false"
        Case vbInteger, vbLong, vbSingle, vbDouble
            buf.Add buf.Count, obj
        Case vbString
            buf.Add buf.Count, """"
            For i = 1 To Len(obj)
                c = Mid(obj, i, 1)
                Select Case c
                    Case """" buf.Add buf.Count, "\"""
                    Case "\"  buf.Add buf.Count, "\\"
                    Case "/"  buf.Add buf.Count, "/"
                    Case b    buf.Add buf.Count, "\b"
                    Case f    buf.Add buf.Count, "\f"
                    Case r    buf.Add buf.Count, "\r"
                    Case n    buf.Add buf.Count, "\n"
                    Case t    buf.Add buf.Count, "\t"
                    Case Else
                        If AscW(c) >= 0 And AscW(c) <= 31 Then
                            c = Right("0" & Hex(AscW(c)), 2)
                            buf.Add buf.Count, "\u00" & c
                            buf.Add buf.Count, c
                End Select
        Case vbArray + vbVariant
            g = True
            buf.Add buf.Count, "["
            For Each i In obj
                If g Then g = False Else buf.Add buf.Count, ","
                buf.Add buf.Count, Encode(i)
            buf.Add buf.Count, "]"
        Case vbObject
            If TypeName(obj) = "Dictionary" Then
                g = True
                buf.Add buf.Count, "{"
                For Each i In obj
                    buf.Add buf.Count, """" & i & """" & ":" & Encode(obj(i))
                buf.Add buf.Count, "}"
                Err.Raise 8732,,"None dictionary object"
        Case Else
            buf.Add buf.Count, """" & CStr(obj) & """"
    End Select
    Encode = Join(buf.Items, "")
'Return the VBScript representation of ``str(``
'Performs the following translations in decoding
'| JSON          | VBScript          |
'| object        | Dictionary        |
'| array         | Array             |
'| string        | String            |
'| number        | Double            |
'| true          | True              |
'| false         | False             |
'| null          | Null              |
Public Function Decode(ByRef str)
    Dim idx
    idx = SkipWhitespace(str, 1)
    If Mid(str, idx, 1) = "{" Then
        Set Decode = ScanOnce(str, 1)
Private Function ScanOnce(ByRef str, ByRef idx)
    Dim c, ms
    idx = SkipWhitespace(str, idx)
    c = Mid(str, idx, 1)
    If c = "{" Then
        idx = idx + 1
        Set ScanOnce = ParseObject(str, idx)
        Exit Function
    ElseIf c = "[" Then
        idx = idx + 1
        ScanOnce = ParseArray(str, idx)
        Exit Function
    ElseIf c = """" Then
        idx = idx + 1
        ScanOnce = ParseString(str, idx)
        Exit Function
    ElseIf c = "n" And StrComp("null", Mid(str, idx, 4)) = 0 Then
        idx = idx + 4
        ScanOnce = Null
        Exit Function
    ElseIf c = "t" And StrComp("true", Mid(str, idx, 4)) = 0 Then
        idx = idx + 4
        ScanOnce = True
        Exit Function
    ElseIf c = "f" And StrComp("false", Mid(str, idx, 5)) = 0 Then
        idx = idx + 5
        ScanOnce = False
        Exit Function
    Set ms = NumberRegex.Execute(Mid(str, idx))
    If ms.Count = 1 Then
        idx = idx + ms(0).Length
        ScanOnce = CDbl(ms(0))
        Exit Function
    Err.Raise 8732,,"No JSON object could be ScanOnced"
Private Function ParseObject(ByRef str, ByRef idx)
    Dim c, key, value
    Set ParseObject = CreateObject("Scripting.Dictionary")
    If c = "}" Then
        Exit Function
    ElseIf c <> """" Then
        Err.Raise 8732,,"Expecting property name"
    idx = idx + 1
    Do
        key = ParseString(str, idx)
        If Mid(str, idx, 1) <> ":" Then
            Err.Raise 8732,,"Expecting : delimiter"
        idx = SkipWhitespace(str, idx + 1)
            Set value = ScanOnce(str, idx)
        ParseObject.Add key, value
        If c = "}" Then
            Exit Do
        ElseIf c <> "," Then
            Err.Raise 8732,,"Expecting , delimiter"
        If c <> """" Then
        idx = idx + 1
    Loop
    idx = idx + 1
Private Function ParseArray(ByRef str, ByRef idx)
    Dim c, values, value
    Set values = CreateObject("Scripting.Dictionary")
    If c = "]" Then
        idx = idx + 1
        ParseArray = values.Items
        Exit Function
    Do
        values.Add values.Count, value
        If c = "]" Then
            Exit Do
        idx = idx + 1
    Loop
    idx = idx + 1
Private Function ParseString(ByRef str, ByRef idx)
    Dim chunks, content, terminator, ms, esc, char
    Set chunks = CreateObject("Scripting.Dictionary")
    Do
        Set ms = StringChunk.Execute(Mid(str, idx))
        If ms.Count = 0 Then
            Err.Raise 8732,,"Unterminated string starting"
        content = ms(0).Submatches(0)
        terminator = ms(0).Submatches(1)
        If Len(content) > 0 Then
            chunks.Add chunks.Count, content
        If terminator = """" Then
            Exit Do
        ElseIf terminator <> "\" Then
            Err.Raise 8732,,"Invalid control character"
        esc = Mid(str, idx, 1)
        If esc <> "u" Then
            Select Case esc
                Case """" char = """"
                Case "\"  char = "\"
                Case "/"  char = "/"
                Case "b"  char = b
                Case "f"  char = f
                Case "n"  char = n
                Case "r"  char = r
                Case "t"  char = t
                Case Else Err.Raise 8732,,"Invalid escape"
            End Select
            idx = idx + 1
            char = ChrW("&H" & Mid(str, idx + 1, 4))
            idx = idx + 5
        chunks.Add chunks.Count, char
    Loop
    ParseString = Join(chunks.Items, "")
Private Function SkipWhitespace(ByRef str, ByVal idx)
    Do While idx <= Len(str) And _
        InStr(Whitespace, Mid(str, idx, 1)) > 0
        idx = idx + 1
    Loop
    SkipWhitespace = idx
End Class
' functions to query url
Function BinaryToString(Binary)
  Dim I,S
  For I = 1 to LenB(Binary)
    S = S & Chr(AscB(MidB(Binary,I,1)))
  BinaryToString = S
Function getURL(URL)
'Create an Http object, use any of the four objects
Dim Http
Dim origHTML
' Set Http = CreateObject("Microsoft.XMLHTTP")
' Set Http = CreateObject("MSXML2.ServerXMLHTTP")
Set Http = CreateObject("MSXML2.ServerXMLHTTP.3.0")
' Set Http = CreateObject("WinHttp.WinHttpRequest.5.1")
'' Set Http = CreateObject("WinHttp.WinHttpRequest")
'Set Http = CreateObject("Microsoft.XmlHttp")
' Set Http = CreateObject("microsoft.xmlhttp")
'Send request To URL
Http.Open "POST", URL, FALSE
Http.Send ""
'Get response data As a string
getURL = BinaryToString(Http.ResponseBody)
'BinaryGetURL = Http.ResponseText
set Httpd = nothing
' EventHandler
   Const apikey ="your api key"
   Const prefix = "[VIRUSTOTAL] "
   Dim oAttachment
   dim filesys
   dim fil
   dim tempName
   For oAttachment = 0 to oMessage.Attachments.Count-1
      Set filesys = CreateObject("Scripting.FileSystemObject")
      tempname = tempPath & filesys.GetTempName '& "_" & oMessage.Attachments(oAttachment).Filename
      oMessage.Attachments(oAttachment).SaveAs(tempname)
      dim hash
      hash = bytesToHex(md5hashBytes(GetBytes(tempname)))
      set fil = filesys.GetFile(tempname)
      fil.Delete
      set fil = Nothing
      set filesys = Nothing
      EventLog.Write ("Checking attachment in VirusTotal: " _
         & oMessage.Attachments(oAttachment).Filename & "  Size : " _
         & oMessage.Attachments(oAttachment).Size & "  Computed MD5 : " & hash)
      ' Test for undesirable attachments
      Dim retVal
      retVal = getURL("https://www.virustotal.com/vtapi/v2/file/report?apikey=" & apikey & "&resource=" & hash)
      If IsNull(retVal) or retVal = "" then
         EventLog.Write ("*** EMPTY response from VirusTotal")
      else
         EventLog.Write ("VirusTotal response: <" & retVal & ">")
         ' get response data
         Set json = New VbsJson
         Set o = json.Decode(retVal)
         dim resp
         dim posit
         resp = o("response_code")
         posit = o("positives")
         if resp = "1" then
            if posit <>"0" then
               oMessage.Subject = prefix & oMessage.Subject
               ' Log in event log
               EventLog.Write ("Email Rejected: Attachment unacceptable: " _
                 & oMessage.Attachments(oAttachment).Size & "  VirusTotal SHA : " & o("sha256"))
               oMessage.Attachments(oAttachment).Delete()
               oMessage.Save()
            else
               EventLog.Write ("Attachment present in VirusTotal but SAFE: " _
            end if
         else
             EventLog.Write ("Attachment not present in VirusTotal: " _
                & oMessage.Attachments(oAttachment).Filename)
         end if
      end if
   Result.Value = 0
Re: Script to check attachments on VirusTotal using VT API
Post by Dravion » 2017-07-20 11:26
Awesome!
I just was wondering how this could be archived.
Keep up the good work!
Post by SorenR » 2017-07-20 15:16
Just a heads-up ... No need to include all the 325 line code in your script. This is what I do.
Option Explicit
   Include("C:\hMailServer\Events\VbsJson.vbs")
   Function Include(sInstFile)
      Dim f, s, oFSO
      On Error Resume Next
      If oFSO.FileExists(sInstFile) Then
         Set f = oFSO.OpenTextFile(sInstFile)
         s = f.ReadAll
         f.Close
         ExecuteGlobal s
      On Error Goto 0
      Set f = Nothing
      Set oFSO = Nothing
   Dim oGeoip, Json : Set Json = New VbsJson
   With CreateObject("Msxml2.ServerXMLHTTP.6.0")
      .Open "GET", "http://www.geoplugin.net/json.gp?ip=" & oClient.IPAddress, False
      .Send
      Set oGeoip = Json.Decode(.responseText)
      If (.Status = 200 ) Then
         EventLog.Write("Countrycode (" & oClient.IPAddress & ") = " & oGeoip("geoplugin_countryCode"))
         EventLog.Write("<OnClientConnect.error> www.geoplugin.net lookup failed, error code: " & .Status & " on IP address " & oClient.IPAddress)
VbsJson.7z
(2.14 KiB) Downloaded 122 times
Post by katip » 2017-07-20 16:11
jamaisx wrote:Actually only do the search for existing scans, so it doesn't submit the file to VT site...
congrats. didn't tried it yet but idea is promising.
FAQ from VT site:
"The 4 requests/minute limitation of the Public API is too low for me, how can I have access to a higher quota?"
there is a long answer. does anyone know the short version, such as "how much"? ;)
thanks.
Post by SorenR » 2017-07-20 17:09
FAQ from VT site:
thanks.
Er...
VirusTotal, a subsidiary of Google, is a free online service that analyzes files and URLs enabling the identification of viruses, worms, trojans and other kinds of malicious content detected by antivirus engines and website scanners. At the same time, it may be used as a means to detect false positives, i.e. innocuous resources detected as malicious by one or more scanners.
VirusTotal’s mission is to help in improving the antivirus and security industry and make the internet a safer place through the development of free tools and services.
The most important rule governing VirusTotal's usage is that none of its publicly offered services/applications should be used in commercial products, commercial services or for any commercial purpose. In the same way, none of the services should be used as a substitute for security products. This is particularly critical and of utmost importance when dealing with the public API.
They just want to know who you are
jamaisx
Post by jamaisx » 2017-07-20 18:20
SorenR wrote:Just a heads-up ... No need to include all the 325 line code in your script. This is what I do.
Thanks, I wrote the script quickly to manage an emergency, let consider it as a draft, also I jave little experience with VbScript...
jamaisx
Post by jamaisx » 2017-07-20 18:22
FAQ from VT site:
thanks.
The script is running from this morning, never received any response saying "too much requests", perhaps the limit is only for the "scan" API
Post by katip » 2017-07-20 18:40
SorenR wrote: They just want to know who you are
jamaisx wrote: The script is running from this morning, never received any response saying "too much requests", perhaps the limit is only for the "scan" API
thanks for comments. also promising...
let's give it a try then.
Post by katip » 2017-07-22 07:06
ok, script works fine. my results after 1 full day:
1. got too many "*** EMPTY response from VirusTotal"
2. it looks up any attachmet, including those tiny images in signatures which are very common. this drains API quota + resources
3. yesterdays zip flood (actually wsf files) such as "01258871901_1057256_632074.zip" with "Subject: Voice Message Attached from..." returned always clean (when not "EMPTY response"), but manual submission from VT site shows many detections - as expected.
#2 is easy. script can be enhanced to submit only certain user defined file extensions.
about other 2 issues i have no idea.
as said, concept is promising (but not so encouraged by VT as i understand).
Post by katip » 2017-07-23 15:11
did some mod in the script:
1. added user defined domains/addreses. i.e. only messages from external domains are processed
oRegExFrom.Pattern = "\@mydomain1\.com|\@mydomain2\.com"
2. added user defined extensions to be hashed and looked up. i.e. only MS docs, pdf, zip... attachments are processed
oRegExAtt.Pattern = "\.doc$|\.docm$|\.docx$|\.dot$|\.dotm$|\.pdf$|\.pot$|\.potm$|\.potx$|\.pps$|\.ppsm$|\.ppsx$|\.ppt$|\.pptx$|\.pub$|\.rar$|\.xls$|\.xlsm$|\.xlsx$|\.xlt$|\.xltm$|\.zip$"
then start checking with:
If Not oRegExFrom.Test(oMessage.FromAddress) then
   If oRegExAtt.Test(oMessage.Attachments(oAttachment).Filename) then
as a result, only certain kind of attachments from external senders are processed and API usage decreased dramatically.
so far no "*** EMPTY response from VirusTotal" or false clean anymore.
i hope this helps to combat zero-hour malware where any particular AV can fail and we simply cannot block daily common attachments.
we'll see..
twaldorf
Post by twaldorf » 2019-05-24 14:00
Has anyone tried randomly using different API keys? Does VT notice that? Is it possible that you will be blocked?
