I would like to block a domain completely.
I have tried using *@domain.com
using *@*.com
as well and it doesn't work
How do I create a rule
The above was a contains
Block Domains
Re: Block Domains
Rules are matched to the SMTP Envelope address. Check the logs to see which domain they are actually sending from.
Re: Block Domains
also possible to block from eventhandlers.vbs script using following to replace commented out OnAcceptMessage section.
if (InStr(1, oMessage.FromAddress, "full or part email address goes in here", 1) > 0) Then
Result.Value = 1
If (Result.Value = 1 ) Then ' Rejected
EventLog.Write("Mail reject:"+Chr(34)+vbTab+oMessage.FromAddress+vbTab+Chr(34)+" ")
End if
Result.Value = 1
End if
Re: Block Domains
Thanks again Percepts
While we are at it is there a script to call a blacklist (txt file) of domains
I know that everyone says it's bad but I have always had good success with it in 12 years. (or add domain onto the below
so it would be for example? I am not a programmer. can do some php but that's it
if (InStr(1, oMessage.FromAddress, "*@*.com", 1) > 0) Then
Result.Value = 1
End if
Result.Value = 1
End if
Re: Block Domains
vbscript is no more complex than PHP and I have only ever cobbled together any vbscript. I don't know if there are any scripts out there that already do what you want but I doubt it.
the eventhandler.vbs script just executes certain subs at certain points during the processing of mailserver communications. You'll have to read the documentation and look to see if there any api calls you can utilise. Since vbscript is available I guess you could do it from the OnClientConnect sub and make it read a txt file and set the return code accordingly. Shouldn't be too difficult if you have the will to do it.
Re: Block Domains
my script to block domians(Set it at :Sub OnAcceptMessage(oClient, oMessage)):
Dim FSO,txtfile,strtxt
If oMessage.FromAddress<>"" Then
set FSO=CreateObject("Scripting.FileSystemObject")
Set txtfile = FSO.OpenTextFile("E:\hMailServer\Events\Black_Domain.txt",1,TriStateTrue)
Do Until txtfile.AtEndOfStream
strtxt = Trim(txtfile.ReadLine)
If (InStr(1,oMessage.FromAddress,strtxt,1)>0) Then
Result.Value = 2
Result.Message ="Your domain is in the local blacklist,server rejected!"
End if
Loop
txtfile.Close
End if
Re: Block Domains
I tried implementing the above script.
But I kep on geeting error messages at line 81
end if statement
Below is my script
Where do I put the above so I don't get the if end error message
Thank you
Sub OnClientConnect(oClient)
Dim geoip
Result.Value =1
set geoip = CreateObject("GeoIPCOMEx.GeoIPEx")
geoip.set_db_path("c:\Program files\hmailserver\geoip\")
geoip.find_by_addr(oClient.IPAddress)
country = geoip.country_code
If (country = "LH" ) Then
Result.Value = 0
End if
If (country = "LN" ) Then
Result.Value = 0
End if
If (country = "GB" ) Then
Result.Value = 0
End if
If (country = "US" ) Then
Result.Value = 0
End if
If (country = "SE" ) Then
Result.Value = 0
End if
If (country = "DE" ) Then
Result.Value = 0
End if
If (country = "CA" ) Then
Result.Value = 0
End if
EventLog.Write("Geo-IP rejected:"+Chr(34)+vbTab+oClient.IPAddress+vbTab+Chr(34) +geoip.country_code+" "+geoip.country_name)
End if
' Sub OnAcceptMessage(oClient, oMessage)
' End Sub
' Sub OnDeliveryStart(oMessage)
' End Sub
' Sub OnDeliverMessage(oMessage)
' End Sub
' Sub OnBackupFailed(sReason)
' End Sub
' Sub OnBackupCompleted()
' End Sub
' End Sub
' End Sub
' End Sub
' End Sub
If LCase(oClient.Username) <> LCase(oMessage.FromAddress) Then
Result.Value = 2
Result.Message = "You are only allowed to send from your own account"
end if statement
Below is my script
Thank you
Dim geoip
Result.Value =1
Result.Value = 0
End if
Result.Value = 0
End if
Result.Value = 0
End if
Result.Value = 0
End if
Result.Value = 0
End if
Result.Value = 0
End if
Result.Value = 0
End if
End if
' End Sub
' End Sub
' End Sub
' End Sub
' End Sub
' End Sub
' End Sub
' End Sub
' End Sub
Result.Value = 2
Re: Block Domains
You need ti add then between "Sub OnAcceptMessage(oClient, oMessage)" and "End Sub"
