Obtaining country and owner of a given IP
ObiWan
Post by ObiWan » 2010-07-28 18:35
The following script can be "linked" to the hMailServer connect event
and will allow you to run DNS queries to retrieve the IP country (TLD)
and the "organization" owning the IP; those infos may then be used
to make decision about accepting or rejecting the transaction
'::::::::: GLOBALS :::::::::::::::
Dim goDNS ' global DNS object
' returns the owner of a given IP
Function GetIPowner(sIPaddr)
  Dim sQuery, sResult, nPos
  Dim vaData, iData, nCol
  On Error Resume Next
  GetIPowner = ""
  If IsPrivateIP(sIPaddr) Then
    ' private IP, skip the check
    Exit Function
  If Not InitDNS(vbTab) Then
    ' failed to init the resolver object
    Exit Function
  ' run the DNS query
  sQuery = ReverseIP(sIPaddr) & ".sa.senderbase.org."
  sResult = QueryDNS(sQuery, "TXT")
  If Len(sResult) < 1 Then
    ' no available infos
    Exit Function
  ' handle multiple records
  vaData = Split(sResult, vbTab)
  For iData = LBound(vaData) To UBound(vaData)
    If Mid(vaData(iData), 2, 1) = "-" Then
      vaData(iData) = Mid(vaData(iData), 3)
  sResult = Join(sResult, "|")
  ' now split the columns and seek the infos
  vaData = Split(sResult, "|")
  sResult = ""
    nPos = InStr(1, vaData(iData), "=")
    If nPos > 0 Then
      nCol = CInt("0" & Mid(vaData(iData), 1, nPos - 1))
      If nCol = 1 Then
        ' column #1 contains the orgname
        sResult = Trim(Mid(vaData(iData), nPos + 1))
        Exit For
  ' all done
  GetIPowner = sResult
' returns the country TLD for the given IP
Function GetIPcountry(sIPaddr)
  Dim sQuery
  GetIPcountry = ""
    Exit Function
    Exit Function
  ' run the DNS query
  sQuery = ReverseIP(sIPaddr) & ".zz.countries.nerd.dk."
  GetIPcountry = QueryDNS(sQuery, "TXT")
' true = the IP is a private one
Function IsPrivateIP(sIP)
  Dim vaOct
  IsPrivateIP = True
  vaOct = Split(sIP, ".")
  If (vaOct(0) = "10") Or (vaOct(0) = "127") Then
    Exit Function ' 10/8 or 127/8
  If (vaOct(0) = "192") And (vaOct(1) = "168") Then
    Exit Function ' 192.168...
  If (vaOct(0) = "169") And (vaOct(1) = "254") Then
    Exit Function ' 169.254... (APIPA)
  If (vaOct(0) = "172") Then
    If (vaOct(1) >= "16") And (vaOct(1) <= "31") Then
      Exit Function ' 172.16/12
  IsPrivateIP = False
' reverses a given IP address
Function ReverseIP(sIP)
  Dim vaOct, iOct, sRev
  sRev = ""
  For iOct = UBound(vaOct) To LBound(vaOct) Step -1
    sRev = sRev & "." & vaOct(iOct)
  ReverseIP = Mid(sRev, 2)
' initialize the resolver object
Function InitDNS(sRecSep)
  Dim sSrv
  InitDNS = False
  Set goDNS = CreateObject("Emmanuel.SimpleDNSClient")
  With goDNS
    .FindServerAddresses sSrv   ' optional
    '.ServerAddresses = sSrv    ' optional
    .Separator = sRecSep        ' results record separator
  If Err.Number <> 0 Then
    trace "InitDNS() ERR: 0x" & Hex(Err.Number) & " " & Err.Description
    Exit Function
  InitDNS = True
' runs a DNS query
Function QueryDNS(sQuery, sType)
  Dim sResult, sRR
  QueryDNS = ""
  sRR = sType
  If sRR = "TXT" Then
    sRR = "TEXT"    ' special case
  sRR = "T_" & sRR  ' add the required prefix
  ' send out the query
  goDNS.Resolve sQuery, sResult, "C_IN", sRR
    trace "QueryDNS() ERR: 0x" & Hex(Err.Number) & " " & Err.Description
    Exit Function
  ' all ok
  QueryDNS = sResult
' trace
Sub trace(sMsg)
  ' add code to trace msgs/errors
note that to use the above script you'll need to pick the DNS resolver object from
this site or use the attached one; the latter is the same object, I just fixed some
minor bugs in the code and rebuilt it; in either case, place the DLL in whatever
suitable folder and register it (regsvr32...); from that point on you'll be able
to call the "GetIPowner(sIPaddr)" or the "GetIPcountry(sIPaddr)" to retrieve
a given IP owner or country
HTH
[edit]
if you'll need to add some trace/debug code to the script, just insert some logging code
inside the trace function and add "trace()" calls where desired
SimpleDNSResolver.zip
COM Wrapper for the Win32 DNS resolver API
(26.09 KiB) Downloaded 327 times
ObiWan
Re: Obtaining country and owner of a given IP
Post by ObiWan » 2010-07-29 17:30
Since we're at it... here's another "version" of that script; this
one is more "generic" since it will allow to retrieve a bunch of
infos and also embeds some "utility functions" (but uses the
same COM DLL used in the previous one)
' DNS query code and service functions start here
Dim goDNS ' global DNS resolver object
' retrieves origin/peer/ASN infos from CYMRU
Function GetCYdata(sData, nType)
  Dim sQuery, sResponse
  Dim vaRec, iRec
  Dim vaCol, iCol
  Dim vaAsn, iAsn
  GetCYdata = ""
  ' check query type
  Select Case nType
    Case 1            ' route origin
      sQuery = ReverseIP(sData) & ".origin.asn.cymru.com."
    Case 2            ' route peers
      sQuery = ReverseIP(sData) & ".peer.asn.cymru.com."
    Case 3            ' ASN infos
      sQuery = "as" & sData & ".asn.cymru.com."
    Case Else         '
      GetCYdata = ""
      Exit Function
  End Select
  ' run the query, check results
  sResponse = DNSquery(sQuery, "TXT")
  If Len(sResponse) < 1 Then
    Exit Function ' no result
  ' handle records
  vaRec = Split(sResponse, vbLf)
  For iRec = LBound(vaRec) To UBound(vaRec)
    sResponse = Trim(vaRec(iRec))
    vaCol = Split(sResponse, "|")
    For iCol = LBound(vaCol) To UBound(vaCol)
      vaCol(iCol) = Trim(vaCol(iCol))   ' trim spaces
    sResponse = Join(vaCol, "|")
    ' do we have multiple ASN in a single record ?
    If InStr(1, vaCol(0), " ") > 0 Then
      ' build a buffer with record data w/o the ASN
      sResponse = ""
      For iCol = 1 To UBound(vaCol)
        sResponse = sResponse & "|" & vaCol(iCol)
      ' split the ASN and rebuild the array
      vaAsn = Split(vaCol(0), " ")
      For iAsn = LBound(vaAsn) To UBound(vaAsn)
        vaAsn(iAsn) = vaAsn(iAsn) & sResponse
      sResponse = Join(vaAsn, vbLf) ' multiple ASN records
      sResponse = Join(vaCol, "|")  ' single ASN record
    vaRec(iRec) = sResponse
  ' all done, return the records "array"
  ' records are separated by vbLf, columns
  ' by the pipe char, each record contains
  ' ASN|CIDR|COUNTRY|SOURCE|LASTUPD
  ' or, in case of ASN queries
  ' ASN|COUNTRY|SOURCE|LASTUPD|OWNER
  GetCYdata = Join(vaRec, vbLf)
' retrieves senderbase data for a given IP
'   0 => 'version_number',
'   1 => 'org_name',
'   2 => 'org_daily_magnitude',
'   3 => 'org_monthly_magnitude',
'   4 => 'org_id',
'   5 => 'org_category',
'   6 => 'org_first_message',
'   7 => 'org_domains_count',
'   8 => 'org_ip_controlled_count',
'   9 => 'org_ip_used_count',
'  10 => 'org_fortune_1000',
'  20 => 'hostname',
'  21 => 'domain_name',
'  22 => 'hostname_matches_ip',
'  23 => 'domain_daily_magnitude',
'  24 => 'domain_monthly_magnitude',
'  25 => 'domain_first_message',
'  26 => 'domain_rating',
'  40 => 'ip_daily_magnitude',
'  41 => 'ip_monthly_magnitude',
'  43 => 'ip_average_magnitude',
'  44 => 'ip_30_day_volume_percent',
'  45 => 'ip_in_bonded_sender',
'  46 => 'ip_cidr_range',
'  47 => 'ip_blacklist_score',
'  50 => 'ip_city',
'  51 => 'ip_state',
'  52 => 'ip_postal_code',
'  53 => 'ip_country',
'  54 => 'ip_longitude',
'  55 => 'ip_latitude',
Function GetSBdata(sIP)
  Dim vaRec, iRec
  Dim vaCol, nCol, nPos
  GetSBdata = ""
  sQuery = ReverseIP(sIP) & ".test.senderbase.org."
  ' split results records
    If Mid(sResponse, 1, 1) = "|" Then
      sResponse = Mid(sResponse, 2)   ' remove leading "|"
    If Mid(sResponse, 2, 1) = "-" Then
      sResponse = Mid(sResponse, 3)   ' remove record#
  sResponse = Join(vaRec, "|")        ' build a single record
  ' turn the results in a positional "array"
  ReDim vaCol(100)
  vaRec = Split(sResponse, "|")
    sResponse = vaRec(iRec)
    nPos = InStr(1, sResponse, "=")
    If nPos > 0 Then
      nCol = CInt("0" & Mid(sResponse, 1, nPos - 1))  ' column #
      If nCol <= 100 Then
        vaCol(nCol) = Trim(Mid(sResponse, nPos + 1))  ' value
  ' all done return the columns "array"
  ' splitting the string into an array will
  ' result in a positional array, so to get
  ' the IP city you'll just have to pick
  ' the array element #50
  GetSBdata = Join(vaCol, "|")
' true = the IP is valid
Function IsValidIP(sIP)
  Dim sBuff, vaOct, iOct, nOct
  IsValidIP = False
  sBuff = Trim(sIP)
  If Len(sBuff) < 1 Then
    Exit Function
  If InStr(1, sBuff, ".") < 1 Then
    Exit Function
  vaOct = Split(sBuff, ".")
  If UBound(vaOct) <> 3 Then
    Exit Function
  For iOct = LBound(vaOct) To UBound(vaOct)
    If Not IsNumeric(vaOct(iOct)) Then
      Exit Function
    nOct = CInt(vaOct(iOct))
    If (nOct < 0) Or (nOct > 255) Then
      Exit Function
  IsValidIP = True
' true = the IP is a "private" one
  Dim vaOct
  IsPrivateIP = True
    Exit Function     ' 169.254/16 (APIPA)
    Exit Function     ' 192.168/16 (used as /24)
  If vaOct(0) = "172" Then
    If (vaOct(1) > "15") And (vaOct(1) < "32") Then
  IsPrivateIP = False
' reverses an IP address
  Dim vaOct, iOct
  Dim sRet
    sRet = sRet & "." & vaOct(iOct)
  ReverseIP = Mid(sRet, 2)
' init/reset DNS engine
Function DNSengine(bStart)
  Dim sDNS
  Set goDNS = Nothing
  If bStart = True Then
    Err.Clear
    Set goDNS = CreateObject("Emmanuel.SimpleDNSclient.1")
      printerr "DNSengine(" & bStart & ")"
      DNSengine = False
      Exit Function
    goDNS.FindServerAddresses sDNS
    goDNS.Separator = vbLf ' records separator
  DNSengine = True
' run a DNS query
Function DNSquery(sQuery, sType)
  Dim sQClass, sQType, sResponse
  sResponse = ""
  DNSquery = sResponse
  sQType = UCase(sType)
  If sQType = "TXT" Then
    sQType = "TEXT"
  sQClass = "C_IN"
  sQType = "T_" & sQType
  Err.Clear
  goDNS.Resolve sQuery, sResponse, sQClass, sQType
    DNSquery = "" '' "0x" & Hex(Err.Number) & ": " & Err.Description
    Exit Function
  DNSquery = Trim(sResponse)
to test the above code, you may just save it as (e.g.) "nsfunc.vbs"
then, just add the following to the top (or bottom) of the script
':::::::::::::: TEST CODE BELOW :::::::::::::::::::::::::
Dim arg
Set arg = WScript.Arguments
WScript.Quit main(arg.Count, arg)
Function main(argc, argv)
  Dim sRet, vaRet, iRet
  Dim sIP
  Dim vaCol
  sIP = "208.67.222.222" ' argv(0)
  ' check if the IP is valid and not private
  If Not IsValidIP(sIP) Then
    main = 1
    Exit Function
  If IsPrivateIP(sIP) Then
    main = 1
    Exit Function
  ' init the DNS resolver object
  If DNSengine(True) = False Then
    main = 1
    Exit Function
  ' route origin (Team CYMRU)
  sRet = GetCYdata(sIP, 1) ' 1=origin infos
  If Len(sRet) < 1 Then
    main = 2
    Exit Function
  WScript.StdOut.WriteLine ":: =========== Route origin "
  vaRet = Split(sRet, vbLf)
  For iRet = LBound(vaRet) To UBound(vaRet)
    WScript.StdOut.WriteLine vaRet(iRet)
  ' ASN infos about route origin(s)
  WScript.StdOut.WriteLine ":: =========== Route origin AS owners"
  'ASN|COUNTRY|SOURCE|LASTUPD|OWNER
    vaCol = Split(vaRet(iRet), "|") ' get record columns
    sRet = GetCYdata(vaCol(0), 3) ' 3=ASN infos
    If Len(sRet) > 0 Then
      WScript.StdOut.WriteLine sRet
  ' route peers (Team CYMRU)
  sRet = GetCYdata(sIP, 2) ' 2=route infos
    main = 2
    Exit Function
  WScript.StdOut.WriteLine ":: =========== Route peering"
  ' ASN infos about route peers
  WScript.StdOut.WriteLine ":: =========== Route peering AS owners"
  ' IP informations (senderbase)
  sRet = GetSBdata(sIP)
    main = 3
    Exit Function
  WScript.StdOut.WriteLine ":: =========== Senderbase"
  ' positional array
  vaCol = Split(sRet, "|")
  For iRet = LBound(vaCol) To UBound(vaCol)
    sRet = Trim(vaCol(iRet))
      WScript.StdOut.WriteLine Left(iRet & String(10, "."), 10) & ": " & vaCol(iRet)
  Call DNSengine(False)
  main = 0
':::::::::::::: TEST CODE ABOVE :::::::::::::::::::::::::
at this point, save the script again and run it through "cscript"
to see the output; I kept the test code quite simple, but it should
allow you to understand how things work
Some notes:
The "CYMRU" queries for IPs may return a single record or multiple
records and in either case, any record may contain multiple ASNs
so the code takes care of that by "exploding" such records so that
the returned results will contain an ASN in each record; on the other
hand, queries related to ASN infos (querytype = 3) will usually return
a single record so you may safely skip the record splitting for those
As for the senderbase, in some cases a query may result in a single
record being splitted amongst a number of answers; the code takes
care of that and also transforms the "tagged" results returned by
senderbase into a "positional" array so that (e.g.) element #50 will
contain the ip city while element #1 will contain the IP owner name
The code also contains generic functions like the ones related to IP
addresses (isvalidip, isprivateip, reverseip) and the one allowing to
run DNS queries; those may be easily used for other purposes (or
at least I hope so)
HTH
Post by percepts » 2010-08-04 16:20
Haven't tried it but I'm sure it works. One word of caution though, I used reverse dns lookups for web stats before and it was very slow. If mail traffic to your server is light you probably won't notice a performance hit. But if your mail server is busy receiving a lot of email, then you may find you get a performance hit.
ObiWan
Post by ObiWan » 2010-08-04 18:41
percepts wrote:Haven't tried it but I'm sure it works. One word of caution though, I used reverse dns lookups for web stats before and it was very slow. If mail traffic to your server is light you probably won't notice a performance hit. But if your mail server is busy receiving a lot of email, then you may find you get a performance hit.
Just a note; PTR queries (reverse lookups) may be really sloooow, I agree about that; but this isn't the case, the zone servers answer immediately with either a response or an NXDOMAIN, so you won't experience the slowdown which happens with PTR queries
HTH
[edit]
PTR type queries may take quite long, since in many case there's no PTR or the AUTH server for the given IP block won't answer at all, this in turn means that the client will have to wait until the timeout expires; on the other hand, senderbase/cymru queries will always get back an immediate answer (even if it's an NXDOMAIN one)
Post by percepts » 2010-08-04 19:09
Iechyd da !
ObiWan
Post by ObiWan » 2010-08-04 19:12
percepts wrote:Iechyd da !
Thanks :D
