Duplicate Mails
ThomasHorst
Duplicate Mails
Post by ThomasHorst » 2009-11-25 19:08
This script discards eMails wich have the same [Message-ID] in the same Download-Job.
It is useful, if you receive messages via a catchall-Account and some providers sending multiple mails according to the cc-Entry.
Have fun
hMailServer 5 - Build 305 @ MS-SQL 2005 x64
Win2k3 R2 x64 Enterprise | NOD32 Business-Edt
SpamAssassin 3.25 native SpamD (Perl 5.8.8.824)
Bladeinger
Re: Duplicate Mails
Post by Bladeinger » 2009-11-27 22:42
Please DO NOT USE this script in the moment! Thomas is a friend of mine and today we accidentally noticed, that this script in rare cases may delete mails unintentionally. Thomas is working on a solution and is looking forward to have a solution soon.
Re: Duplicate Mails
Post by ^DooM^ » 2009-11-27 23:27
I removed the old file.
jamesp
Re: Duplicate Mails
Post by jamesp » 2017-02-24 22:11
Can you share the script as a reference?
Re: Duplicate Mails
Post by mattg » 2017-02-25 13:26
FYI
Thunderbird has an 'add-on' called 'remove duplicate messages'
It works a treat and looks at message content, not just GUID
Re: Duplicate Mails
Post by jimimaseye » 2017-02-25 13:34
mattg wrote:FYI
TB has a builtin feature (not requiring an addon) - you must need to enable it
mail.server.default.dup_action set to:
  • 0 - this is the default value. It retrieves duplicate mails like normal mails.
    1 - if you set the value to 1 duplicate mails will be deleted automatically once retrieved
    2 - if you set the value to 2 duplicated mails will be moved right into the trash
    3 - the value 3 finally marks duplicate mails as read
(I dont use it though so no idea on what criteria it used or how effective it is).
