Copy to imap folder
Conzi
Copy to imap folder
Post by Conzi » 2020-01-15 12:33
it would be useful for me (and for others tough) to have the rule "copy to IMAP folder" in addition to "move to IMAP folder"
I need to distribute the same email (digitally signed) to multple address... the rule forward breaks the digital sign; move to IMAP folder is ok, but
it can only be used once (for a single mail)
thanks
Re: Copy to imap folder
Post by SorenR » 2020-01-15 14:59
Conzi wrote:
2020-01-15 12:33
thanks
Not quite so simple... Allthough you can use "move to IMAP folder" in a global rule executed as "administrator", it is actually executed as an "account rule" with the rights of the receiving mail account. It simply cannot see the other accounts.
It will require some major rewriting of the Rules engine to do this.
An alternative solution is to enable public folders, create a folder, assign rights to this folder amongst the accounts in question and move the email to that folder.
Go to hMailServer Administrator -> Settings -> Protocols -> IMAP [Public folders]
Click on "Edit folders"
Right click on left pane and select "Create folder"
Type name and click on "Edit permissions"
Add accounts and set permissions.
Default folder name is "#Public" and default folder separator is "." so if you create "MailAShare" you will need to move to IMAP folder "#Public.MailAShare".
Conzi
Post by Conzi » 2020-01-15 16:55
2020-01-15 14:59
Conzi wrote:
2020-01-15 12:33
I'm already doing this way... but I would have preferred to have one public folder per user
thanks for your time :-D
Post by mattg » 2020-01-15 23:22
I don't understand this bit...
Conzi wrote:
2020-01-15 16:55
Can you please explain that bit in more detail
Conzi
Post by Conzi » 2020-01-17 15:33
2020-01-15 23:22
Conzi wrote:
2020-01-15 16:55
with "move to imap folder" i can move the email to only one user (only one public folder, as every user has one)
but often I need to move same email to many user, sometime same email to one user, sometime to two user and so on, with rules.
I cant' user "forward" or distribution list, because breaks digital signature.
The email are downloaded via pop3 from another server, so... for every user I have to download the same emails (and duplicate the rules)
Using "copy to imap folder" repeated for the user I need (with rules) will be perfect (only one download via pop3 then copy to imap folder rules...)
Post by SorenR » 2020-01-17 17:53
Not sure how good your scripting skills are and I have no idea if this breaks digital sign but it is something I have played with as part of some code to deliver email with illegal attachments to "Postmaster" before hMailServer actually remove the attachment(s) and deliver to account... Just in case of false-positives 8)
Function CloneMail(oMessage, strRecipient, strAddress, strHeader)
    '   CloneMail(oMessage, "Wile E. Coyote", "wile.e.coyote@acme.inc", "X-hMailServer-Cloned")
    Dim strFilename
    If oMessage.HeaderValue(strHeader) = "YES" Then Exit Function
        strFilename = .Filename
            .CopyFile oMessage.Filename, strFilename, True
        .RefreshContent
        .AddRecipient strRecipient, strAddress
        .Save
Post by mattg » 2020-01-18 02:52
Conzi wrote:
2020-01-17 15:33
2020-01-15 23:22
Conzi wrote:
2020-01-15 16:55
Can't multiple accounts access the same #public.folder
