Rules "or" and "and" together
odseg
Post by odseg » 2013-07-10 12:21
Good day, i use hmail 5.3, i use many rules and & or , this called one question, is it possible to do use rules "or" and "and" together?
for example: field subject contain some word "OR" body contain some word "AND" field "to" contain some address
sorry for my English
Re: Rules "or" and "and" together
Post by jimimaseye » 2014-08-03 23:58
I agree. Would be useful. But would be difficult i think.
Post by ^DooM^ » 2014-08-04 00:18
Yes i have needed this a few times. Normally just turn to scripting if you need more advanced rules.
Post by SorenR » 2014-08-04 16:28
I split them into two rules, first rule create a custom header value and second rule check for the header value and the remaining criterias.
Post by jimimaseye » 2015-03-12 12:11
REGEX is a beauty for helping out in these situations.
EG,
Where
RETURN PATH EQ axp.fraudite.com
and
TO contains USER1
or
TO contains USER2
could be written as
and
TO regex (?i:^.*(USER1@|USER2@).*$)
Regex can do CONTAIN, NOT CONTAINS(using the asterix), EQUALS, NOT EQUALS (removing the asterix) - but not sure how to do 'Greater Than' etc - im no expert.
(Admitedly, though, you cant do where IF FIELD1=xxx and (Field2=yyy or Field3=zzz). So I too am still up for the ability to do so if it happens.
