Add DNS server setting [90%]
Need DNS Setting
yes
11
52%
no.
10
48%
Total votes: 21
yon
Post by yon » 2012-03-22 18:33
I need add dns setting for hmail server. I can't use local dns .
Re: Add DNS server setting
Post by Bill48105 » 2012-03-22 19:13
Been awhile since I looked at the code but I *think* it shouldn't be too bad to add but odds are I'd do INI's at 1st like I've done with other settings. I imagine 99.99% of the time people can just use their Windows DNS servers but suspect there could be times where it'd be handy to be able to over-ride & set different ones so worth looking into.
yon
Post by yon » 2012-03-22 19:26
Bill48105 wrote:Been awhile since I looked at the code but I *think* it shouldn't be too bad to add but odds are I'd do INI's at 1st like I've done with other settings. I imagine 99.99% of the time people can just use their Windows DNS servers but suspect there could be times where it'd be handy to be able to over-ride & set different ones so worth looking into.
because our Country ISP block some DNS and a lot of site ip, So my build local dns server only for over block firewall. So I have to config dns setting in hmail server user other normal dns server for mx records so on.
Post by Bill48105 » 2012-03-22 19:28
yon wrote:because our Country ISP block some DNS and a lot of site ip, So my build local dns server only for over block firewall. So I have to config dns setting in hmail server user other normal dns server for mx records so on.
That makes sense but what I'm missing though is why that special local dns server can't be set in Windows too.. Can't you just set your Windows DNS to 127.0.0.1 or LAN IP of computer running DNS locally?
yon
Post by yon » 2012-03-23 14:15
So my dns sevrer using IPv6 NAT DNS. all domain ipv4 address will change to ipv6 address. IP over DNS. :wink:
Post by Bill48105 » 2012-03-23 14:31
yon wrote:So my dns sevrer using IPv6 NAT DNS. all domain ipv4 address will change to ipv6 address. IP over DNS. :wink:
So you can't just setup your own dns server & point your windows to it causing hmail to use it?
yon
Post by yon » 2012-03-29 04:02
yes. my dns server will mx ipv4 address auto change to ipv6 address.
ObiWan
Post by ObiWan » 2012-04-02 09:46
yon wrote:I need add dns setting for hmail server. I can't use local dns .
Install a DNS on the hMS box, either the regular windows DNS or the unbound one, configure the DNS to forward queries to whatever other external or local DNS servers you want and point the IP settings of the local machine to the local DNS (be it 127.0.0.1 or the local IP); no need to change hMS for such a task and sincerely, IPv6 or not, I see NO problem at all in doing the above
yon
Post by yon » 2012-04-02 15:16
my local DNS can't work for hmail server. it is for other service.
just like altn mdameon can setup dns.
Each network environment has different needs.
our country ISP blocked a lot of DNS server , ip address and domains. So we have to find other ways for it.
ObiWan
Post by ObiWan » 2012-04-02 15:40
yon wrote:my local DNS can't work for hmail server. it is for other service.
Sorry but I'm not following you; probably it's due to the fact that I'm not a native english speaker, but sincerely, what you wrote, from a "tech" standpoint doesn't make sense at all. See, having a local DNS resolver means that you will then be able to setup conditional forwarding for whatever domain and to handle all your DNS resolution by yourself either by using recursion or by leveraging whatever external resolver as a forwarder. So, there's no "different needs" just an "explain with full details what you need and I/we may be able to help you"; there's no other way to address issues and in any case I don't think that the solution is changing the hMS code; there are a NUMBER (not kidding) other ways to achieve the same result w/o touching the code and, in general, a mailserver is just a piece of code running on a given host, and it obeys the host settings when it comes to network stuff (IP address, DNS ... and so on)
Bottom line, try getting a grip on what was already suggested since I *do* believe that your solution sits in there
dzekas
Post by dzekas » 2012-04-02 18:03
I think forum already has other feature request for it. It has long discussion and response from martin.
Post by Bill48105 » 2012-04-02 23:58
After looking at code this shouldn't be too hard to add but not sure how useful to how many people it will be if done. Maybe I'll look into it further when I get time but it'd be nice to hear from more than 1 person that this would be useful. :D
ObiWan
Post by ObiWan » 2012-04-03 08:36
Bill48105 wrote:After looking at code this shouldn't be too hard to add but not sure how useful to how many people it will be if done. Maybe I'll look into it further when I get time but it'd be nice to hear from more than 1 person that this would be useful. :D
Well, adding it won't be so difficult, just a matter of using a given array of DNS servers IPs when initializing the DNS resolver APIs; basically you'll need something like (code coming from some stuff I wrote time ago, just pasted some snippets)
    PIP4_ARRAY pSrvList = NULL;
    fOptions = DNS_QUERY_STANDARD;
    if (NULL != lpstrServer) {
      // we got a server name or IP, use it for the query
      pSrvList = (PIP4_ARRAY)LocalAlloc(LPTR,sizeof(IP4_ARRAY));
      if (!pSrvList) {
        // bomb with error since we need this list
        printerror("pSrvList", GetLastError());
        return(-1);
      // retrieve the IP (in binary format)
      ulDNS = GetDNSaddr(lpstrServer);
      if (INADDR_NONE == ulDNS) {
        // not a valid IP (or unresolvable host name)
        return(-2);
      pSrvList->AddrCount = 1;
      pSrvList->AddrArray[0] = ulDNS;
      fOptions = DNS_QUERY_BYPASS_CACHE;
    // run the query
    nStatus = DnsQuery(lpstrQuery, wType, fOptions, pSrvList, &pDnsRecords, NULL);
notice that the above only uses ONE DNS, by the way the code may be easily adapted to deal with multiple DNS servers (just a matter or allocating a proper size array and setting the count), also notice that whenever specifying DNS server(s) you'll need to add the "bytpass cache" flag or the query will fail; this has also a side effect, that is, the local DNS resolver cache (the windows DNS client/cache service) won't be populated with the results from the query and this, in turn, will slow things down a bit
That said, and given that as you wrote the change won't require too much effort, I think that adding an optional entry to the "ini" file allowing to specify the DNS server(s) to use may be the most straightforward way to implement such a feature; in this case the "ini" may contain something like (e.g.)
DNSresolvers=11.22.33.44,55.66.77.88,99.0.1.2
that is a comma separated list of IP addresses pointing to the DNS servers you want hMS to use; by the way, if the entry is blank or missing, hMS will just use the default resolver(s) as it does now
HTH
Post by Bill48105 » 2012-04-03 18:14
ObiWan: Thx yeah that essentially the plan if we moved forward with this. Again I was waiting to see if more people would find this helpful. Obviously there are tons of things people are wanting, and most before this too. When I work on stuff I weigh it on my time available, how useful it'll be, how much time it'll take & how likely it will break something. This one seems like it'll take little time & likely won't break anything (at least could be tested easily) but I'm quite busy with life ATM & so far not looking like this will be super useful to people.
ObiWan
Post by ObiWan » 2012-04-03 18:19
Bill48105 wrote:ObiWan: Thx yeah that essentially the plan if we moved forward with this. Again I was waiting to see if more people would find this helpful. Obviously there are tons of things people are wanting, and most before this too. When I work on stuff I weigh it on my time available, how useful it'll be, how much time it'll take & how likely it will break something. This one seems like it'll take little time & likely won't break anything (at least could be tested easily) but I'm quite busy with life ATM & so far not looking like this will be super useful to people.
No problem, Bill and sincerely I don't see the need for such a feature so ... well, if you'll find time, add it, otherwise keep it in the backburner and give precedence to other stuff (and RL comes first btw :D); as a note - not willing to hijack the thread - I think that implementing SRS would be more important that such DNS stuff altough... ok, it would take much more time/effort, I know
Oh well, I'll stop here :)
Post by Bill48105 » 2012-04-03 18:26
Yes you did hijack it & go off topic even after you said weren't going to. :P
Regarding your priorities, take SRS for example. In terms of my above criteria for when I work on stuff consider yes SRS would be very helpful to many people (although one could argue we all survive without it & it can be done in scripting), it would take a lot of time, is very likely to break something, I still have very little free time ATM. So 1 yay, 3 nays on SRS. ;)
Anyway yeah please don't trash up yon's thread more with further off-topic stuff. Feel free to create a new one if you want to discuss further. :)
Thx
dzekas
Post by dzekas » 2012-04-03 18:42
Post by Bill48105 » 2012-04-03 18:51
Thx for the link dzekas. That is from 2009, that is ancient history! lol
I see martin had no interest in hmail having option to define DNS servers..
dzekas: I see from your other replies you didn't see a need either.. Do you still feel that way or do you think yon's situation shows a need? Or is there a work-around?
Thx
dzekas
Post by dzekas » 2012-04-03 21:57
Bill48105 wrote:Do you still feel that way or do you think yon's situation shows a need? Or is there a work-around?
local dns service can forward requests to ISPs dns. For ISP there is no difference between workstation and other service which forwards unknown zone lookups to it. I can find other similar topic on this forum, where I asked user to setup local dns properly instead of asking for alternative dns settings.
hMailServer is an application. Alternative dns only makes it more complex. You can't test how it works, if your local telnet app uses one dns and smtp server uses something different. DNS settings must be shared between all applications for lookup consistency and management.
ObiWan
Post by ObiWan » 2012-04-04 08:48
Agreed; the only real need for different DNS settings may be for the cases when you have control on the mailserver (hMailServer) but not over the system (so can't change the DNS settings or the like); in such a case, being able to point the mailserver to a different DNS may be somewhat useful - but in general, as I wrote, I don't see a need for such a feature
Post by Bill48105 » 2012-04-05 20:32
yon,
Seems when specifying dns servers for the query you lose out on resolver caching because it requires the DNS_QUERY_BYPASS_CACHE flag. Not sure how that'll affect performance vs using system dns but something to consider or look into.
Also, I'm not sure on using ipv6 dns servers with DnsQuery.. Would using an ipv4 IP suffice or do you need ipv6 for the server for your needs? Have a feeling there are a ton of changes needed for ipv6 still.. Since i don't use ipv6 or have any need for it I can't say for sure.
yon
Post by yon » 2012-04-06 08:26
DNS forward can't normal in our country. I have said, Country ISP Block all other country DNS servser,even IANA's DNS server.
Because the country ISP blocked all ipv4 network, so I using ipv6 dns and ipv6 adress point to ipv4 address.
but mail server need mormal others dns server.
About dns forwarding
http://forums.jhsoft.com/default.aspx?g=posts&t=429
yon
Post by yon » 2012-04-06 08:31
well.., from 2009?
Requests for additional functionality is very difficult. :(
yon
Post by yon » 2012-04-06 08:40
How I visit blocked ipv4 address? I am using ipv6 address forwarding to ipv4 address.
and dns forward must use TCP.
Because Government will Tampering with dns data when use udp for dns forward.
dzekas
Post by dzekas » 2012-04-06 16:44
yon wrote:DNS forward can't normal in our country.
DNS forwarding is one of your dns server configuration options. It has nothing to do with your country. If you ask for alternative DNS option, you do have access to unfiltered DNS. Use that unfiltered DNS as your primary DNS service on your email server.
If this option is implemented in hMailServer, will you go to Microsoft, Mozilla, OpenOffice and others asking for same thing in every program they produce?
ObiWan
Post by ObiWan » 2012-04-07 15:35
or either, just use a 6to4 tunnel so that you'll have a public IPv6 and will be able to also "talk" v6 to external hosts and perform v6 resolution (given that the DNS you use is able to deal with IPv6); that way all the traffic, be it v4 or v6 will be tunnelled over v6 but will be still able to reach both v4 or v6 hosts; again I think the whole point is totally UNRELATED to hMailServer and has to be dealt otherwise; as an example, try looking at this, the doc may help you understanding how to setup IPv6 on your box(es) and deciding which approach you want to use (ensure to read through parts 1...3)
ObiWan
Post by ObiWan » 2012-04-07 16:00
Bill48105 wrote:yon,
Bill, as I wrote in another reply, I think that all this isn't a thing for hMailServer; what he needs is just to setup a 6to4 tunnel with whatever broker (e.g. Sixx or whatever) and then run his system over Ipv6, but this is NOT an issue with hMS, just a matter of correctly configuring the host system(s) :)
Post by Bill48105 » 2012-04-07 18:42
It's easy to discount what other people need when you're not the one in their shoes. ;) Like I said before, it'd be great to find a working solution & preferably not 1/2-ass hacks. In terms of comparing hmail to other programs so it shouldn't have DNS option, to me that is bull. An email server is not 'Word' or just any other program so it could have special needs in certain circumstances. And it's always nice to have options available when the need arises. I don't understand why yon says he needs it but no doubt he believes it or he wouldn't be asking. But even though I don't understand his need I'm not writing off the possibility of adding dns to hmail either. Hopefully someone can come with something for him & not just bashing the idea or his situation.
ObiWan
Post by ObiWan » 2012-04-08 17:50
Bill48105 wrote:It's easy to discount what other people need when you're not the one in their shoes. ;) Like I said before, it'd be great to find a working solution & preferably not 1/2-ass hacks. In terms of comparing hmail to other programs so it shouldn't have DNS option, to me that is bull. An email server is not 'Word' or just any other program so it could have special needs in certain circumstances. And it's always nice to have options available when the need arises. I don't understand why yon says he needs it but no doubt he believes it or he wouldn't be asking. But even though I don't understand his need I'm not writing off the possibility of adding dns to hmail either. Hopefully someone can come with something for him & not just bashing the idea or his situation.
I understand your point, Bill, but let me say that hMailServer (if I'm not wrong) is a mail server and, trying to let it be everything to everyone isn't imHo a good idea since it may then end being nothing to nobody :) - that said, the DNS settings are relatively easy to implement, so, if you think they're worth, go for them; but sincerely, I do believe that a better solution for the issue would be installing an IPv6 tunnel s/w on the box so letting whatever app running on it transparently talking v6; that won't need any change to the s/w and will (most probably) allow to achieve the desired result.
Post by ^DooM^ » 2012-04-08 20:12
I agree with Bill on this one. I believe hMail should have the ability to set it's own DNS servers. It should only be available via INI setting though and not added to the ini by default. This would leave hMail as is but for only those that really have no other choice but to change them. I had a hosting provider that has all their windows servers using something similar to opendns except it was serving up affiliate links for his own company which is not very good for a mailserver as has been discussed previously. I could not install a local DNS server as the provider would not allow it so I eventually moved to a different provider. Having the ability to change the DNS servers there would have been a huge help in that regard.
I vote to add the ability to hMail under the conditions I stated above :)
yon
Post by yon » 2012-04-17 04:36
I think it is an very simply Function, I don't know why your can't understand it.
the altn's mdaemon mail server support this function.
http://www.altn.com/Support/KnowledgeBa ... =KBA-01280
ObiWan
Post by ObiWan » 2012-04-17 10:22
yon wrote:I think it is an very simply Function, I don't know why your can't understand it.
I don't think it's a matter of understanding it; on the opposite, I believe we understood what you're asking, it's just that, aside from the exceptions discussed in this thread, such a feature doesn't seem to be all that useful; but then, given that it should be relatively easy to implement (using an "ini" entry)... why not :) - as for the Alt-N mDaemon, that dialog made me laugh; see, asking for the hosts file path just means that whoever designed it didn't understand how the file fits inside the resolution process; there's NO need imHo to specify the path of the hosts file since it will be automatically accessed by the resolver - at any rate, and again, it's up to the devs; if they think they may just slip in such a change w/o wasting too much time then... be it
yon
Post by yon » 2012-04-18 21:59
I not need edit hosts file. just altn mdaemon has hosts edit gui,only for user easy use it. so some user not so know how network manager.
One more consideration is the user's use of the environment.
As much as possible to make the product easier to use. Perhaps this is a design idea. like This is why the windows system does not disappear, easy to use. :wink:
dzekas
Post by dzekas » 2012-04-18 22:18
yon wrote:This is why the windows system does not disappear, easy to use. :wink:
try switching language in windows and then find out how language is changed in other systems. count interpreters and shells available in windows and in other oses.
yon
Post by yon » 2012-06-15 17:17
my default dns server transfer and change ipv4 to ipv6.
echoDreamz
Post by echoDreamz » 2013-06-25 20:51
I am adding my vote for this.
Post by Bill48105 » 2014-02-08 08:07
2014-02-08 5.4-B2014020801
* IMPORTANT: This build has a LOT of extra debug logging by default. Disable using [Settings]LogLevel=7 or lower
* Added ability to set custom DNS servers in INI DnsServers=192.168.1.33
* Only 1 DNS server for now! IPv6 compatibility UNKNOWN
ObiWan
Post by ObiWan » 2014-03-03 09:51
As a note, had a look at the DNS resolver source code found here (I think that's the latest version) and it sounds like it isn't using that flag the "DNS_QUERY_BYPASS_CACHE" option is commented out; I think you should add a check like (warning: air code)
 DWORD fOptions;
 if (blnUseExternalDNS)
   // bypass cache if using external resolvers
   fOptions |= DNS_QUERY_BYPASS_CACHE;
otherwise, queries using external resolvers would fail.
As for the cache, while it's true that using that flag will have the effect of NOT populating the local dns resolver cache, on the other hand, it won't have any effect on the external DNS resolver cache, so the resolver will still populate its cache (but the local DNS client won't) so it shouldn't possibly be a big issue
Re: Add DNS server setting [90%]
Post by Bill48105 » 2014-03-04 07:31
Thx ObiWan but you're quoting me from something almost 2 years ago when this was being discussed.. If you look I added option for setting dns servers but have yet to have a single person try it & provide feedback so no idea if it even works beyond my brief testing.
As far as how it was done I simply used windows built-in dns resolver and yes bypass cache option is set just as MS says to. but it's only set IF dns servers are set in the ini otherwise windows default dns servers are used & bypass cache is not changed so it should be enabled.
ObiWan
Post by ObiWan » 2014-03-04 15:42
Bill48105 wrote:Thx ObiWan but you're quoting me from something almost 2 years ago when this was being discussed.. If you look I added option for setting dns servers but have yet to have a single person try it & provide feedback so no idea if it even works beyond my brief testing.
Mumble... so you're sayin' that the code found here
http://hmailserver.com:60951/svn/hms/tr ... solver.cpp
is outdated ?? If so... where do I find the latest code :) ?
Post by Bill48105 » 2014-03-04 20:08
source changes have not been posted yet just pre-compiled experimental build for people to try & report back
