am currently migrating from Mail Enable so thought i'd spend some time making a tool to save me a lot of work. Though, quite possibly, have spent a little more time on making it than it would have took to copy the data over manually, is a lot less boring tough
This is the first release and can copy over the following from ME to hMail:
Post Office Name to Domain Name
Domain Status
All Mail Accounts in each post office
Mailbox Status
Each Mailbox password (with option to encrypt)
I almost have the forward to email addresses, status of forwarding and whether to keep a local copy of forwarded mail.
But in the final testing i started having trouble with duplicate entries when passing the ME config file into a dataset, will fix soon. However in it's current state it works a treat and saves a lot of effort when migrating over from ME.. enjoy.
oh, for first run i recommend running it in a command prompt, if the Mail Enable path is not set correctly in the .ini file it will crash.. not got round to the error capture on that yet
Also, any requests or suggestions for features for this tool will be gratefully received..
**LATEST VERSION BELOW**
