Auto-generate "All Users" lists for each domain
C_Alden
Post by C_Alden » 2008-01-29 01:34
This is a simple script I came up with to automatically generate distribution lists for all domains that will include all accounts in the domain. For best results (i.e. the most up-to-date list), it should be run as frequently as possible; I find that nightly suits our needs well enough.
' hMailServer All Users List script
' Creates and maintains a distribution list that reaches all mailboxes
' By C. Alden
'Settings:
'Password for hMailServer Administrator
strAdminPassword = "password"
'Distribution List Name
strDistributionList = "AllUsers"
' ***          Code starts here          ***
' Create COM objects to interact with hMailServer
obBaseApp.Authenticate "Administrator",strAdminPassword
intDomainCount = obBaseApp.Domains.Count
for i = 0 to (intDomainCount - 1)
	Set obDomain = obBaseApp.Domains.Item(i)
	Set obList = Nothing
	Set obRecipent = Nothing
	'See if list already exists; if so, delete it
	strListAddress = strDistributionList & "@" & obDomain.Name
	On Error Resume Next
	Set obList = obDomain.DistributionLists.ItemByAddress(strListAddress)
	On Error Goto 0
	If Not (obList Is Nothing) Then
		obList.Delete()
	Set obList = obDomain.DistributionLists.Add()
	obList.Address = strListAddress
	obList.Save()
	'Step through user accounts and add them to list
	intUserCount = obDomain.Accounts.Count
	For j = 0 to (intUserCount - 1)
		Set obRecipient = Nothing
		Set obAccount = obDomain.Accounts.Item(j)
		Set obRecipient = obList.Recipients.Add()
		obRecipient.RecipientAddress = obAccount.Address
		obRecipient.Save()
Pern
Re: Auto-generate "All Users" lists for each domain
Post by Pern » 2011-01-12 23:21
works great thanks and works on hmailserver 5 too
Johnny - aka Pern
marceloleaes
Post by marceloleaes » 2018-06-19 03:15
It works perfectly
For my use only one resource was missing, I use the @ allusers groups but only one user can send to this group. Would it be possible to set this user in the list option via script?
Post by mattg » 2018-06-19 08:09
Add one line between these two
obList.Save()
The line to add should be something like
obList.RequireSenderAddress = "sender@example.com"
This would make a single sender for ALL domains.
But then my question is why not use the 'server sendout' utility?
marceloleaes
Post by marceloleaes » 2018-06-19 13:59
I did not really realize it would change for all domains ..
But for installations where there is only one domain will serve.
The send to all in Hmail you say?
This problem would release the user with admin from the domain ..
Post by jimimaseye » 2018-06-19 15:16
I did a SERVERSENDOUT script for the individual domain here: viewtopic.php?p=179547#p179547
