Minor doc error
ras07
Minor doc error
Post by ras07 » 2018-06-01 19:58
The changelog for the beta says "Upgrade to OpenSSL 1.0.1o" - pretty sure it should be 1.0.2o
https://www.hmailserver.com/changelog/?version=5.6.8
Re: Minor doc error
Post by mattg » 2018-06-02 00:16
I agree that it probably should be 2, but I can't change that
I'll send a link to this post to Martin
Re: Minor doc error
Post by Dravion » 2018-06-02 13:07
OpenSSL in hMailServer needs to upgrade to the 1.1.x Mainline.
Version 1.0.x is running out of support next year:
Note: The latest stable version is the 1.1.0 series. The 1.0.2 series is our Long Term Support (LTS) release, supported until 31st December 2019. The 0.9.8, 1.0.0 and 1.0.1 versions are now out of support and should not be used.
https://www.openssl.org/source/
