5.7.0-B2414
mns17
5.7.0-B2414
Post by mns17 » 2017-03-25 11:27
Mattg, Martin, can you patch one SQL query in Messages.cpp?
from
String sql = "update hm_messages set messageflags = messageflags & ~ @FLAGS where messageaccountid = @ACCOUNTID and messagefolderid = @FOLDERID;
to
String sql = "update hm_messages set messageflags = messageflags & ~ @FLAGS where messageaccountid = @ACCOUNTID and messagefolderid = @FOLDERID and NOT messageflags = messageflags & ~ @FLAGS";
This patch will speed up the request
Thx!
Re: 5.7.0-B2414
Post by jimimaseye » 2017-03-25 13:49
Enter your request, advice or DIY fix here: https://github.com/hmailserver/hmailserver/issues/
Re: 5.7.0-B2414
Post by Dravion » 2017-03-25 16:07
Create a patch on Github
1) Create a Github account
2) Assemble your fix
3) Create a pull request
