Mail routing
yuzsekiz
Mail routing
Post by yuzsekiz » 2016-10-17 08:58
Hi everyone,
according to the following topologies;
Is hMAIL mails to redirect the correct server?
best regards.
O.K.
Conzi
Re: Mail routing
Post by Conzi » 2016-11-05 17:56
if the dns correctly shows the mx ip for those domains, then yes, hMailServer will route emails correctly.
Anyway you can use static routes inside hmailserver
