Experimental-specific problems/questions
mns17
Post by mns17 » 2012-11-21 05:17
Hi, All
Version HMail is 5.4-B2012052801, DB is MSSQL 2008 R2, Charset Cyrillic_General_CI_AS
If create IMAP.Folder "Отправленные" (RUS) in HMailAdmin, then its folder is invisible in e-mail client like MS Outlook (2007, 2010), webmail Roundcube and ...
If create IMAP.Folder "Отправленные" (RUS) in e-mail clients, then in HMailAdmin name of this folder "От,BEAEMAQyBDsENQQ9BD0ESwQ1-"
If create IMAP.Folder "От,BEAEMAQyBDsENQQ9BD0ESwQ1-" in HMailAdmin, then name of this folder in e-mail client like MS Outlook (2007, 2010), webmail Roundcube and ... "От,BEAEMAQyBDsENQQ9BD0ESwQ1-"
In DB:
IMAP.Folder "Отправленные" (RUS) created in HMailAdmin = "&BB4EQgQ/BEAEMAQyBDsENQQ9BD0ESwQ1-"
IMAP.Folder "Отправленные" (RUS) created in e-mail clients = "&BB4EQgQ,BEAEMAQyBDsENQQ9BD0ESwQ1-"
IMAP.Folder "От,BEAEMAQyBDsENQQ9BD0ESwQ1-" (RUS) created in HMailAdmin = "&BB4EQg-,BEAEMAQyBDsENQQ9BD0ESwQ1-"
If in names of IMAP.Folders in-email clients symbol №3 is "п" (RUS) then in HMailAdmin all symbol after be in coding like "ка,BDoEMAQ9-" In original is "капкан"
If in names of IMAP.Folders HMailAdmin symbol №3 is "п" (RUS) then its invisible in e-mail clients... (((
This Error present in:
hMailServer 5.4 - 1944
hMailServer 5.4 - 1942
hMailServer 5.4-B2012052801
This NOT present in:
hMailServer 5.3.3 - Build 1879
Thx
Anton
DavidB
Re: Experimental-specific problems/questions
Post by DavidB » 2012-11-21 05:37
Hi, I'm not sure about the language/encoding side,
Creating the folder is one thing, with IMAP until you "subscribe" to the folder it will not become visible in your email client or webmail.
EG: i have a spam filter, if a message is classified as spam move the message to the "Junk-EMail" folder, if the folder doesn't exist it creates it(EG for new users receiving their first spam). My customers cannot see this folder until they first look at the IMAP folder list in Outlook or Webmail and subscribe to the "Junk-EMail" Folder.
In short, after creating the folder in HmailAdmin make sure you subscribe to the folder first, otherwise you will not see it.
mns17
Post by mns17 » 2012-11-21 05:42
Folder list is upgrade in web-mail jr e-mail clients, but folder is invisible.
mns17
Post by mns17 » 2013-01-21 11:47
hMailServer 5.4 - 1945
